查看: 6708|回复: 0
XE7导入导出excel数据
发表于 2015-8-4 12:12:31 | 显示全部楼层 |阅读模式
   前段时间我在做有关XE7(更准确的说是c++ builder)导入导出excel数据的应用,在网上找了一下,感觉做excel的导入导出,一般有两种方法:ole 和 XE7自带office2k控件,前者相对来说网上资源更多,做的人也更多,后者网上资源比较零散,做的人也较少,由于个人比较喜欢用控件做,还是选择了后者,XE7要先安装office2k控件,默认XE7是没装的,然后添加TExcelApplication控件,TExcelWorkBook控件,TExcelWorkSheet控件,再然后是写代码,下面附上自己写的代码
void __fastcall TForm1::ImportPlan(TObject *Sender)             //导入
     uint16_t i, j;
    AnsiString  FileName = ExtractFilePath(Application->ExeName) + mPlanFile;
    ExcelApplication1->Connect();
    ExcelWorkbook1->ConnectTo(ExcelApplication1->Workbooks->Open((Variant)FileName, TNoParam(), TNoParam(), TNoParam(),TNoParam(),TNoParam(),TNoParam(), TNoParam(),TNoParam(),TNoParam(),TNoParam(), TNoParam(), TNoParam(), 0));
    ExcelWorksheet1->ConnectTo(ExcelWorkbook1->Worksheets->get_Item((Variant)(1)));
    int Bounds[4] = {0, 93, 0, 9};
    Variant Datas = VarArrayCreate(Bounds, 3, varVariant);
    for(i = 0; i < 93; i++)
        for(j = 0; j < 10; j++)
            Datas.PutElement(ExcelWorksheet1->Cells->get_Item((Variant)(i + 1),(Variant)(j + 1)), i, j);
    //需要判断excel行数小于机台个数***********//
    for(int i = 0; i < 92; i++)
        mDev1 = Datas.GetElement(i + 1, 0);
void __fastcall TForm1::ExportPlan(TObject *Sender)           //导出{
     AnsiString s;    int Bounds[4] = {0, 93, 0, 1};
    AnsiString  FileName = ExtractFilePath(Application->ExeName) +FormatDateTime("yyyy-mm-dd",Date()) + ".xls";    ExcelApplication1->Connect();
    ExcelWorkbook1->ConnectTo(ExcelApplication1->Workbooks->Add(TNoParam(),0));    ExcelWorksheet1->ConnectTo(ExcelWorkbook1->Worksheets->get_Item((Variant)(1)));
    ExcelWorksheet1->get_Columns()->set_ColumnWidth((Variant)18);
    ExcelWorksheet1->Cells->set_Item((Variant)1, (Variant)1, (Variant)"日期");
    for(int i = 0; i < 92; i++)    {
        Datas.PutElement(Date(), i, 0);    }
    ExcelWorksheet1->get_Range((ExcelWorksheet1->Cells->get_Item((Variant)1,(Variant)1)),(ExcelWorksheet1->Cells->get_Item((Variant)93,(Variant)1)))->set_Value(Datas);    ExcelWorkbook1->SaveAs((Variant)FileName, (Variant)39, TNoParam(), TNoParam(), TNoParam(), TNoParam(), 1, TNoParam(), TNoParam(), TNoParam(), TNoParam(), 0);
    ExcelWorksheet1->Disconnect();    ExcelWorkbook1->Disconnect();
    ExcelApplication1->Disconnect();    ExcelApplication1->Workbooks->Close(0);
}office控件做excel可以看office 2000 excel的VBA帮助文档,VBA是专门设计excel的编程语言,里面的一些控件的方法和参数跟office控件的方法和参数大致相同。最后再附上一个资料网址
http://wenku.baidu.com/link?url= ... 6FCVQlsvetHAxPxHbz_
GMT+8, 2026-11-22 13:30 , Processed in 0.813961 second(s), 23 queries .
