查看: 1570|回复: 2
[技术讨论] 求助iic通信问题
发表于 2023-7-17 16:02:02 | 显示全部楼层 |阅读模式
         在调试两个模块,从机的iic读写想调用主机的,但是从机读写没有寄存器地址,应该怎么操作
uint8_t hal_gh30x_i2c_write(uint8_t device_id, const uint8_t write_buffer[], uint16_t length)//从机写函数
uint8_t hal_gh30x_i2c_read(uint8_t device_id, const uint8_t write_buffer[], uint16_t write_length, uint8_t read_buffer[], uint16_t read_length)//从机读函数
uint8_t iic_write_bytes(enum iic_channel_t channel, uint8_t slave_addr, uint8_t reg_addr, uint8_t *buffer, uint16_t length)
    volatile struct iic_reg_t *iic_reg;
    if(length == 0)
        return true;
    length--;
    if(channel == IIC_CHANNEL_0)
        iic_reg = IIC0_REG_BASE;
        iic_reg = IIC1_REG_BASE;
    iic_reg->data = slave_addr | IIC_TRAN_START;
    while(iic_reg->status.trans_emp != 1);
    co_delay_10us(iic_byte_period[channel]);
    if(iic_reg->status.no_ack == 1)
        return false;
    iic_reg->data = reg_addr & 0xff;
    while(length)
        while(iic_reg->status.trans_ful == 1);
        iic_reg->data = *buffer++;
        length--;
    iic_reg->data = *buffer | IIC_TRAN_STOP;
    while(iic_reg->status.bus_atv == 1);
    return true;
uint8_t iic_read_bytes(enum iic_channel_t channel, uint8_t slave_addr, uint8_t reg_addr, uint8_t *buffer, uint16_t length)
    if(length == 0)
        return true;
        return false;
    iic_reg->data = slave_addr | 0x01 | IIC_TRAN_START;
    while(length > 1)
        iic_reg->data = 0x00;
        while(iic_reg->status.rec_emp != 1)
            *buffer++ = iic_reg->data;
            length--;
    iic_reg->data = IIC_TRAN_STOP;
    while(length)
        length--;
    *buffer = iic_reg->data&0xff;
    return true;
发表于 2023-7-17 16:04:02 | 显示全部楼层
意思是从机主动给主机发消息吗,这个不支持,不知道楼主说的是不是这个意思 。
 楼主| 发表于 2023-7-17 16:09:54 来自手机 | 显示全部楼层
едiicд涼дЩ
GMT+8, 2026-11-28 18:22 , Processed in 1.194903 second(s), 24 queries .
