查看: 1975|回复: 0
[FreeRTOS] FreeRTOS中断优先级有效性检测函数vPortValidateInterruptPriority强制要求NVIC优先级分组必须是全抢占优先级
发表于 2023-7-6 01:06:36 | 显示全部楼层 |阅读模式
重要说明:
For simplicity all bits must be defined  to be pre-emption priority bits.  The following assertion will fail if  this is not the case (if some bits represent a sub-priority)
源函数:
        void vPortValidateInterruptPriority( void )
        uint32_t ulCurrentInterrupt;
        uint8_t ucCurrentPriority;
                /* Obtain the number of the currently executing interrupt. */
                ulCurrentInterrupt = vPortGetIPSR();
                /* Is the interrupt number a user defined interrupt? */
                if( ulCurrentInterrupt >= portFIRST_USER_INTERRUPT_NUMBER )
                        /* Look up the interrupt's priority. */
                        ucCurrentPriority = pcInterruptPriorityRegisters[ ulCurrentInterrupt ];
                        /* The following assertion will fail if a service routine (ISR) for
                        an interrupt that has been assigned a priority above
                        configMAX_SYSCALL_INTERRUPT_PRIORITY calls an ISR safe FreeRTOS API
                        function.  ISR safe FreeRTOS API functions must *only* be called
                        from interrupts that have been assigned a priority at or below
                        configMAX_SYSCALL_INTERRUPT_PRIORITY.
                        Numerically low interrupt priority numbers represent logically high
                        interrupt priorities, therefore the priority of the interrupt must
                        be set to a value equal to or numerically *higher* than
                        Interrupts that        use the FreeRTOS API must not be left at their
                        default priority of        zero as that is the highest possible priority,
                        which is guaranteed to be above configMAX_SYSCALL_INTERRUPT_PRIORITY,
                        and        therefore also guaranteed to be invalid.
                        FreeRTOS maintains separate thread and ISR API functions to ensure
                        interrupt entry is as fast and simple as possible.
                        The following links provide detailed information:
                        [url=http://www.freertos.org/RTOS-Cortex-M3-M4.html]http://www.freertos.org/RTOS-Cortex-M3-M4.html[/url]
                        [url=http://www.freertos.org/FAQHelp.html]http://www.freertos.org/FAQHelp.html[/url] */
                        configASSERT( ucCurrentPriority >= ucMaxSysCallPriority );
                /* Priority grouping:  The interrupt controller (NVIC) allows the bits
                that define each interrupt's priority to be split between bits that
                define the interrupt's pre-emption priority bits and bits that define
                the interrupt's sub-priority.  For simplicity all bits must be defined
                this is not the case (if some bits represent a sub-priority).
                If the application only uses CMSIS libraries for interrupt
                configuration then the correct setting can be achieved on all Cortex-M
                devices by calling NVIC_SetPriorityGrouping( 0 ); before starting the
                scheduler.  Note however that some vendor specific peripheral libraries
                assume a non-zero priority group setting, in which cases using a value
                of zero will result in unpredictable behaviour. */
                configASSERT( ( portAIRCR_REG & portPRIORITY_GROUP_MASK ) <= ulMaxPRIGROUPValue );
GMT+8, 2026-11-24 15:15 , Processed in 1.003087 second(s), 24 queries .
