查看: 2002|回复: 1
[FreeRTOS] FreeRTOS上电创建首个任务初始化的几个链表
发表于 2023-7-4 09:15:32 | 显示全部楼层 |阅读模式
task.c文件:
static void prvInitialiseTaskLists( void )
UBaseType_t uxPriority;
        for( uxPriority = ( UBaseType_t ) 0U; uxPriority < ( UBaseType_t ) configMAX_PRIORITIES; uxPriority++ )
                vListInitialise( &( pxReadyTasksLists[ uxPriority ] ) );
        vListInitialise( &xDelayedTaskList1 );
        vListInitialise( &xDelayedTaskList2 );
        vListInitialise( &xPendingReadyList );
        #if ( INCLUDE_vTaskDelete == 1 )
                vListInitialise( &xTasksWaitingTermination );
        #endif /* INCLUDE_vTaskDelete */
        #if ( INCLUDE_vTaskSuspend == 1 )
                vListInitialise( &xSuspendedTaskList );
        #endif /* INCLUDE_vTaskSuspend */
        /* Start with pxDelayedTaskList using list1 and the pxOverflowDelayedTaskList
        using list2. */
        pxDelayedTaskList = &xDelayedTaskList1;
        pxOverflowDelayedTaskList = &xDelayedTaskList2;
 楼主| 发表于 2023-7-5 01:27:20 | 显示全部楼层
链表解析
	UBaseType_t uxTaskGetSystemState( TaskStatus_t * const pxTaskStatusArray, const UBaseType_t uxArraySize, uint32_t * const pulTotalRunTime )
	UBaseType_t uxTask = 0, uxQueue = configMAX_PRIORITIES;
		vTaskSuspendAll();
			/* Is there a space in the array for each task in the system? */
			if( uxArraySize >= uxCurrentNumberOfTasks )
				/* Fill in an TaskStatus_t structure with information on each
				task in the Ready state. */
				do
					uxQueue--;
					uxTask += prvListTasksWithinSingleList( &( pxTaskStatusArray[ uxTask ] ), &( pxReadyTasksLists[ uxQueue ] ), eReady );
				} while( uxQueue > ( UBaseType_t ) tskIDLE_PRIORITY ); /*lint !e961 MISRA exception as the casts are only redundant for some ports. */
				task in the Blocked state. */
				uxTask += prvListTasksWithinSingleList( &( pxTaskStatusArray[ uxTask ] ), ( List_t * ) pxDelayedTaskList, eBlocked );
				uxTask += prvListTasksWithinSingleList( &( pxTaskStatusArray[ uxTask ] ), ( List_t * ) pxOverflowDelayedTaskList, eBlocked );
				#if( INCLUDE_vTaskDelete == 1 )
					each task that has been deleted but not yet cleaned up. */
					uxTask += prvListTasksWithinSingleList( &( pxTaskStatusArray[ uxTask ] ), &xTasksWaitingTermination, eDeleted );
				#endif
					each task in the Suspended state. */
					uxTask += prvListTasksWithinSingleList( &( pxTaskStatusArray[ uxTask ] ), &xSuspendedTaskList, eSuspended );
				#endif
				#if ( configGENERATE_RUN_TIME_STATS == 1)
					if( pulTotalRunTime != NULL )
						#ifdef portALT_GET_RUN_TIME_COUNTER_VALUE
							portALT_GET_RUN_TIME_COUNTER_VALUE( ( *pulTotalRunTime ) );
						#else
							*pulTotalRunTime = portGET_RUN_TIME_COUNTER_VALUE();
						#endif
				#else
						*pulTotalRunTime = 0;
				#endif
				mtCOVERAGE_TEST_MARKER();
		( void ) xTaskResumeAll();
		return uxTask;
GMT+8, 2026-11-24 15:14 , Processed in 0.916870 second(s), 24 queries .
