查看: 2360|回复: 3
[MDK] MDK烧录失败,求助
发表于 2023-6-26 14:52:12 | 显示全部楼层 |阅读模式
Load "TEST_WIFI\\TEST_WIFI.axf"
Internal parameter error
File       : D:/Arm/Packs/Keil/STM32H7xx_DFP/3.1.0/Keil.STM32H7xx_DFP.pdsc
Sequence   : DebugDeviceUnlock -> CheckID
Context    : Item #0: <block>:ine 11
Expression : "
E310       : Debug access failed - cannot read address 0xE00E0FE4 (accsize '4', AP '0x00000002')
Erase Done.
Programming Done.
Verify OK.
Application running ...
Flash Load finished at 14:44:48
报错如上,"Internal parameter error"该如何解决,网上看了一圈都没看到具体的解释和操作方法。
 楼主| 发表于 2023-6-26 16:53:55 | 显示全部楼层
在外网搜到解决方案了:
1. uncheck “Debug Description - Enable” on the Pack tab.
After that, the device disappears from the SW Device list on the Debug tab - but this is not an error.
2. uncheck “Update Target before Debugging” in Utilities tab
原帖地址:https://community.arm.com/suppor ... n-t-debug-a-project ,最底下的回复
 楼主| 发表于 2023-6-26 16:52:11 | 显示全部楼层
在外网搜到解决方案了:
发表于 2023-6-27 08:29:48 | 显示全部楼层
ST的nucleo板子我也遇到过类似错误。
ST的NUCLEO板子无法下载程序时,通过复位状态下载可解决
https://forum.anfulai.cn/forum.p ... 9538&fromuid=58
GMT+8, 2026-11-24 15:56 , Processed in 0.151452 second(s), 26 queries .
