查看: 2211|回复: 5
[SPI/QSPI] 移植下载算法报错
发表于 2023-6-20 10:05:28 | 显示全部楼层 |阅读模式
Erase Done.
Programming Done.
Contents mismatch at: 90000000H  (Flash=88H  Required=06H) !
Contents mismatch at: 90000001H  (Flash=88H  Required=48H) !
Contents mismatch at: 90000002H  (Flash=88H  Required=80H) !
Contents mismatch at: 90000003H  (Flash=88H  Required=47H) !
Contents mismatch at: 90000004H  (Flash=88H  Required=06H) !
Contents mismatch at: 90000005H  (Flash=88H  Required=48H) !
Contents mismatch at: 90000006H  (Flash=88H  Required=00H) !
Contents mismatch at: 90000007H  (Flash=88H  Required=47H) !
Contents mismatch at: 90000008H  (Flash=88H  Required=FEH) !
Contents mismatch at: 90000009H  (Flash=88H  Required=E7H) !
Contents mismatch at: 9000000AH  (Flash=88H  Required=FEH) !
Contents mismatch at: 9000000BH  (Flash=88H  Required=E7H) !
Contents mismatch at: 9000000CH  (Flash=88H  Required=FEH) !
Contents mismatch at: 9000000DH  (Flash=88H  Required=E7H) !
Contents mismatch at: 9000000EH  (Flash=88H  Required=FEH) !
Contents mismatch at: 9000000FH  (Flash=88H  Required=E7H) !
Contents mismatch at: 90000010H  (Flash=88H  Required=FEH) !
Contents mismatch at: 90000011H  (Flash=88H  Required=E7H) !
Contents mismatch at: 90000012H  (Flash=88H  Required=FEH) !
Contents mismatch at: 90000013H  (Flash=88H  Required=E7H) !
Contents mismatch at: 90000014H  (Flash=88H  Required=FEH) !
Contents mismatch at: 90000015H  (Flash=88H  Required=E7H) !
Contents mismatch at: 90000016H  (Flash=88H  Required=FEH) !
Contents mismatch at: 90000017H  (Flash=88H  Required=E7H) !
Contents mismatch at: 90000018H  (Flash=88H  Required=FEH) !
Contents mismatch at: 90000019H  (Flash=88H  Required=E7H) !
Contents mismatch at: 9000001AH  (Flash=88H  Required=FEH) !
Contents mismatch at: 9000001BH  (Flash=88H  Required=E7H) !
Contents mismatch at: 9000001CH  (Flash=88H  Required=EDH) !
Contents mismatch at: 9000001DH  (Flash=88H  Required=48H) !
Contents mismatch at: 9000001EH  (Flash=88H  Required=00H) !
Contents mismatch at: 9000001FH  (Flash=88H  Required=90H) !
Contents mismatch at: 90000020H  (Flash=88H  Required=99H) !
Contents mismatch at: 90000021H  (Flash=88H  Required=02H) !
Contents mismatch at: 90000022H  (Flash=88H  Required=00H) !
Contents mismatch at: 90000023H  (Flash=88H  Required=08H) !
Contents mismatch at: 90000024H  (Flash=88H  Required=2DH) !
Contents mismatch at: 90000025H  (Flash=88H  Required=E9H) !
Contents mismatch at: 90000026H  (Flash=88H  Required=F0H) !
Contents mismatch at: 90000027H  (Flash=88H  Required=5FH) !
Contents mismatch at: 90000028H  (Flash=88H  Required=05H) !
Contents mismatch at: 90000029H  (Flash=88H  Required=46H) !
Contents mismatch at: 9000002AH  (Flash=88H  Required=00H) !
Contents mismatch at: 9000002BH  (Flash=88H  Required=20H) !
Contents mismatch at: 9000002CH  (Flash=88H  Required=92H) !
Contents mismatch at: 9000002DH  (Flash=88H  Required=46H) !
Contents mismatch at: 9000002EH  (Flash=88H  Required=9BH) !
Contents mismatch at: 9000002FH  (Flash=88H  Required=46H) !
Contents mismatch at: 90000031H  (Flash=88H  Required=46H) !
Contents mismatch at: 90000032H  (Flash=88H  Required=06H) !
Contents mismatch at: 90000033H  (Flash=88H  Required=46H) !
Contents mismatch at: 90000034H  (Flash=88H  Required=81H) !
Contents mismatch at: 90000035H  (Flash=88H  Required=46H) !
Contents mismatch at: 90000036H  (Flash=88H  Required=40H) !
Contents mismatch at: 90000037H  (Flash=88H  Required=24H) !
Contents mismatch at: 90000038H  (Flash=88H  Required=1BH) !
Contents mismatch at: 90000039H  (Flash=88H  Required=E0H) !
Contents mismatch at: 9000003AH  (Flash=88H  Required=28H) !
Contents mismatch at: 9000003BH  (Flash=88H  Required=46H) !
Contents mismatch at: 9000003CH  (Flash=88H  Required=41H) !
Contents mismatch at: 9000003DH  (Flash=88H  Required=46H) !
Contents mismatch at: 9000003EH  (Flash=88H  Required=47H) !
Contents mismatch at: 9000003FH  (Flash=88H  Required=46H) !
Contents mismatch at: 90000040H  (Flash=88H  Required=22H) !
Contents mismatch at: 90000041H  (Flash=88H  Required=46H) !
Contents mismatch at: 90000042H  (Flash=88H  Required=00H) !
Contents mismatch at: 90000043H  (Flash=88H  Required=F0H) !
Contents mismatch at: 90000044H  (Flash=88H  Required=69H) !
Contents mismatch at: 90000045H  (Flash=88H  Required=F8H) !
Contents mismatch at: 90000046H  (Flash=88H  Required=53H) !
Contents mismatch at: 90000047H  (Flash=88H  Required=46H) !
Contents mismatch at: 90000048H  (Flash=88H  Required=5AH) !
Contents mismatch at: 90000049H  (Flash=88H  Required=46H) !
Contents mismatch at: 9000004AH  (Flash=88H  Required=C0H) !
Contents mismatch at: 9000004BH  (Flash=88H  Required=1AH) !
Contents mismatch at: 9000004CH  (Flash=88H  Required=91H) !
Contents mismatch at: 9000004DH  (Flash=88H  Required=41H) !
Contents mismatch at: 9000004EH  (Flash=88H  Required=10H) !
Contents mismatch at: 9000004FH  (Flash=88H  Required=D3H) !
Contents mismatch at: 90000050H  (Flash=88H  Required=11H) !
Contents mismatch at: 90000051H  (Flash=88H  Required=46H) !
Contents mismatch at: 90000052H  (Flash=88H  Required=18H) !
Contents mismatch at: 90000053H  (Flash=88H  Required=46H) !
Contents mismatch at: 90000054H  (Flash=88H  Required=22H) !
Contents mismatch at: 90000055H  (Flash=88H  Required=46H) !
Contents mismatch at: 90000056H  (Flash=88H  Required=00H) !
Contents mismatch at: 90000057H  (Flash=88H  Required=F0H) !
Contents mismatch at: 90000058H  (Flash=88H  Required=50H) !
Contents mismatch at: 90000059H  (Flash=88H  Required=F8H) !
Contents mismatch at: 9000005AH  (Flash=88H  Required=2DH) !
Contents mismatch at: 9000005BH  (Flash=88H  Required=1AH) !
Contents mismatch at: 9000005CH  (Flash=88H  Required=67H) !
Contents mismatch at: 9000005DH  (Flash=88H  Required=EBH) !
Contents mismatch at: 9000005EH  (Flash=88H  Required=01H) !
Contents mismatch at: 9000005FH  (Flash=88H  Required=08H) !
Contents mismatch at: 90000060H  (Flash=88H  Required=4FH) !
Contents mismatch at: 90000061H  (Flash=88H  Required=46H) !
Contents mismatch at: 90000062H  (Flash=88H  Required=22H) !
Contents mismatch at: 90000063H  (Flash=88H  Required=46H) !
Contents mismatch at: 90000064H  (Flash=88H  Required=01H) !
Too many errors to display !
Error: Flash Download failed  -  "Cortex-M7"
Flash Load finished at 09:55:34
取消校验,可以下载成功,但程序无法正常运行
移植了硬汉哥的H743xb下载算法到H750xb(8M QSPI FLASH,引脚,容量已修改)上烧录程序报错,求求大佬们帮帮忙
发表于 2023-6-20 11:10:13 | 显示全部楼层
不同系列的指令略有不同,对比下所有调用的指令。
 楼主| 发表于 2023-6-20 20:44:44 | 显示全部楼层
修改了指令也是一样的错误
发表于 2023-6-21 08:49:54 | 显示全部楼层
国产娃娃菜 发表于 2023-6-20 20:44
修改了指令也是一样的错误
修改指令后,你单独在一个工程里面测试这些函数正常不,如果正常那就作为FLM工程就方便测试很多了。
发表于 2025-4-4 16:19:48 | 显示全部楼层
修改了指令也是一样的错误
求问楼主问题解决了吗?是如何解决的
发表于 2025-4-8 16:21:12 | 显示全部楼层
我也遇到,你把Keil里的 Flash Download 里的Verify不要勾选就行了。或者加个校验函数
GMT+8, 2026-10-24 16:20 , Processed in 1.163726 second(s), 27 queries .
