查看: 2328|回复: 1
[DSP] 请问关于反正切函数的具体使用方法!
发表于 2023-5-29 09:23:05 | 显示全部楼层 |阅读模式
arm_status arm_atan2_f32(float32_t y,float32_t x,float32_t *result)
  Computing Arc tangent only using the ratio y/x is not enough to determine the angle
  since there is an indeterminacy. Opposite quadrants are giving the same ratio.
  ArcTan2 is not using y/x to compute the angle but y and x and use the sign of y and x
  to determine the quadrant.
这里说明的是,是确定象限的,请问一下,各位知道这个具体的使用方法是怎么样的吗?
发表于 2023-5-29 10:11:34 | 显示全部楼层
和C库的atan2一样。区别C是返回值值,ARM库这个是形参返回。
GMT+8, 2026-11-28 18:10 , Processed in 0.172451 second(s), 24 queries .
