查看: 2676|回复: 2
[IAR] IAR提示:Call to a non __ramfunc function from within a __ramfunc function
发表于 2023-5-28 11:58:42 | 显示全部楼层 |阅读模式
官方对此的描述:
IAR Embedded Workbench Release History
[EWARM-6744] When a non-ramfunc function is inlined into a __ramfunc function, warning Ta023 "Call to a non __ramfunc function from within a __ramfunc function" is issued. This is incorrect; after the call is inlined there is no call, and the inlined code is inside the caller, which is a __ramfunc function.
屏蔽警告方法:
https://github.com/hrshygoodness ... /emlib/src/em_msc.c
#ifdef __CC_ARM  /* MDK-ARM compiler */
#pragma arm section code="ram_code"
#endif /* __CC_ARM */
#if defined(__ICCARM__)
/* Suppress warnings originating from use of EFM_ASSERT():              */
/* "Call to a non __ramfunc function from within a __ramfunc function"  */
/* "Possible rom access from within a __ramfunc function"               */
#pragma diag_suppress=Ta022
#pragma diag_suppress=Ta023
#endif
发表于 2023-5-28 13:51:11 | 显示全部楼层
这个为何会引起警告,会有什么问题吗?
 楼主| 发表于 2023-5-28 17:14:02 | 显示全部楼层
tangqianfeng 发表于 2023-5-28 13:51
这个为何会引起警告,会有什么问题吗?
如果不是错误,仅是警告的话,屏蔽了就行。
GMT+8, 2026-10-25 13:28 , Processed in 0.357153 second(s), 24 queries .
