查看: 1890|回复: 4
[ThreadX全家桶] Fliex使用标准库修改硬汉哥综合模板驱动,fx_media_open时提示FX_MEDIA_INVALID (0x02)
发表于 2023-3-19 00:08:56 | 显示全部楼层 |阅读模式
芯片使用F405RGT6,Freertos可以正常读取sd卡,使用filex移植时不成功,找来硬汉哥例程,使用标准库sd卡驱动修改后,fx_media_open打开媒体时返回0x02,微软官方服务说明是“FX_MEDIA_INVALID (0x02) 指定媒体的启动扇区已损坏或无效。 此外,此返回代码用于指示逻辑扇区缓存大小或 FAT 条目大小不是 2 的幂。”
实在是头大,代码粘贴如下:
/*       Partial Copyright (c) Microsoft Corporation. All rights reserved.*/
/*       This software is licensed under the Microsoft Software License   */
/*       Terms for Microsoft Azure RTOS. Full text of the license can be  */
/*       found in the LICENSE file at [url]https://aka.ms/AzureRTOS_EULA[/url]       */
/*       and in the root directory of this software.                      */
/*      Partial Copyright (c) STMicroelctronics 2020. All rights reserved */
/* Include necessary system files.  */
#include "fx_stm32_sd_driver.h"
#include "fx_api.h"
#include "sdio_sd.h"
#include "usart.h"
UINT  _fx_partition_offset_calculate(void  *partition_sector, UINT partition, ULONG *partition_start, ULONG *partition_size);
static UINT sd_read_data(FX_MEDIA *media_ptr, ULONG sector, UINT num_sectors, UINT use_scratch_buffer);
static UINT sd_write_data(FX_MEDIA *media_ptr, ULONG sector, UINT num_sectors, UINT use_scratch_buffer);
static TX_SEMAPHORE transfer_semaphore;
static uint8_t is_initialized = 0;
static int32_t check_sd_status()
    uint32_t start = tx_time_get();
    while (tx_time_get() - start < DEFAULT_TIMEOUT)
      if (SD_GetStatus() == SD_TRANSFER_OK)
        return 0;
    return 1;
  * @brief This function is the entry point to the STM32 SDIO disk driver.     */
 /*        It relies on the STM32 peripheral library from ST.
  * @param None
  * @retval None
VOID  fx_stm32_sd_driver(FX_MEDIA *media_ptr)
    int32_t status;
    ULONG       partition_start;
    ULONG       partition_size;
#if (FX_DRIVER_CALLS_BSP_SD_INIT == 0)
    is_initialized = 1; /* the SD  was initialized by the application*/
#endif
//TX_INTERRUPT_SAVE_AREA
   /* before performing any operation, check the status of the SDMMC */
    if (is_initialized == 1)
      if (check_sd_status() != 0)
          media_ptr->fx_media_driver_status =  FX_IO_ERROR;
          return;
    /* Process the driver request specified in the media control block.  */
    switch(media_ptr->fx_media_driver_request)
        case FX_DRIVER_INIT:
#if (FX_DRIVER_CALLS_BSP_SD_INIT == 1)
            /* Initialize the SD instance */
            if (is_initialized == 0)
                status = SD_Init();
                if (status == 0)
                    is_initialized = 1;
#endif
                    /* create a binary semaphore to check the DMA transfer status */
                    if (tx_semaphore_create(&transfer_semaphore, "sdmmc dma transfer semaphore", 0) != TX_SUCCESS)
                        media_ptr->fx_media_driver_status =  FX_SUCCESS;
#endif
        case FX_DRIVER_UNINIT:
            tx_semaphore_delete(&transfer_semaphore);
            SD_DeInit();
            is_initialized = 0;
#endif
            /* Successful driver request.  */
        case FX_DRIVER_READ:
            //TX_DISABLE /* disable interrupts */
           if ((ULONG)(media_ptr->fx_media_driver_buffer) & 0x3)
              if (sd_read_data(media_ptr, media_ptr->fx_media_driver_logical_sector + media_ptr->fx_media_hidden_sectors,
                                media_ptr->fx_media_driver_sectors, 1) == FX_SUCCESS)
                       media_ptr->fx_media_driver_sectors, 0) == FX_SUCCESS)
           //TX_RESTORE /* restore interrupts */
        case FX_DRIVER_WRITE:
           if (sd_write_data(media_ptr, media_ptr->fx_media_driver_logical_sector + media_ptr->fx_media_hidden_sectors,
        case FX_DRIVER_FLUSH:
            /* Return driver success.  */
        case FX_DRIVER_ABORT:
        case FX_DRIVER_BOOT_READ:
            /* the boot sector is the sector 0 */
//            status = BSP_SD_ReadBlocks_DMA((uint32_t*)media_ptr->fx_media_driver_buffer, 0, 1);
            status = SD_ReadMultiBlocks((uint8_t *)media_ptr->fx_media_driver_buffer, 0, 512, 1);
//            status = SD_ReadBlock((uint8_t *)media_ptr->fx_media_driver_buffer, 0, 1);
            status = SD_WaitReadOperation();
             while(SD_GetStatus() != SD_TRANSFER_OK);
            tx_semaphore_put(&transfer_semaphore);
            if (status != 0)
            if(tx_semaphore_get(&transfer_semaphore, DEFAULT_TIMEOUT) != TX_SUCCESS)
            /* Check if the sector 0 is the actual boot sector, otherwise calculate the offset into it.
            Please note that this should belong to higher level of MW to do this check and it is here
            as a temporary work solution */
            partition_start =  0;
            status =  _fx_partition_offset_calculate(media_ptr -> fx_media_driver_buffer, 0,
        &partition_start, &partition_size);
            /* Check partition read error.  */
            if (status)
                /* Unsuccessful driver request.  */
                media_ptr -> fx_media_driver_status =  FX_IO_ERROR;
                return;
            /* Now determine if there is a partition...   */
            if (partition_start)
                    return;
                /* Yes, now lets read the actual boot record.  */
//                status = BSP_SD_ReadBlocks_DMA((uint32_t*)media_ptr -> fx_media_driver_buffer, partition_start , 1);
                /* Check status of SDIO Read.  */
                if (status != 0)
                    return;
                /* Wait for Rx Transfer completion */
            media_ptr -> fx_media_driver_status =  FX_SUCCESS;
        case FX_DRIVER_BOOT_WRITE:
//            status = BSP_SD_WriteBlocks_DMA((uint32_t*)media_ptr->fx_media_driver_buffer, 0, 1);
            status = SD_WriteMultiBlocks((uint8_t *)media_ptr->fx_media_driver_buffer, 0, 512, 1);
//            status = SD_WriteBlock((uint8_t *)media_ptr->fx_media_driver_buffer, 0, 1);
            if (status == 0)
                if(tx_semaphore_get(&transfer_semaphore, DEFAULT_TIMEOUT) == TX_SUCCESS)
        default:
  * @brief BSP Tx Transfer completed callbacks
  * @param Instance the SD instance
  * @retval None
//void BSP_SD_WriteCpltCallback()
//    tx_semaphore_put(&transfer_semaphore);
//  * @brief BSP Rx Transfer completed callbacks
//  * @param Instance the sd instance
//  * @retval None
//void BSP_SD_ReadCpltCallback()
  * @brief Read buffer using BSP SD API taking into account the scratch buffer
  * @param FX_MEDIA *media_ptr a pointer the main FileX structure
  * @param ULONG start_sector first sector to start reading from
  * @param UINT num_sectors number of sectors to be read
  * @param UINT use_scratch_buffer to enable scratch buffer usage or not.
  * @retval FX_SUCCESS on success FX_BUFFER_ERROR otherwise
static UINT sd_read_data(FX_MEDIA *media_ptr, ULONG start_sector, UINT num_sectors, UINT use_scratch_buffer)
    UINT status;
    //status = BSP_SD_ReadBlocks_DMA((uint32_t*)media_ptr->fx_media_driver_buffer, start_sector, num_sectors);
    status = SD_ReadMultiBlocks((uint8_t *)media_ptr->fx_media_driver_buffer, start_sector, 512, num_sectors);
    if (status == 0)
            status =  FX_BUFFER_ERROR;
    return status;
  * @brief write buffer using BSP SD API taking into account the scratch buffer
  * @param ULONG start_sector first sector to start writing from
  * @param UINT num_sectors number of sectors to be written
static UINT sd_write_data(FX_MEDIA *media_ptr, ULONG start_sector, UINT num_sectors, UINT use_scratch_buffer)
    UINT status;
    //BSP_SD_WriteBlocks_DMA(uint32_t *pData, uint32_t WriteAddr, uint32_t NumOfBlocks)
//    BSP_SD_WriteBlocks_DMA((uint32_t*)media_ptr->fx_media_driver_buffer, start_sector, num_sectors);
    status = SD_WriteMultiBlocks((uint8_t *)media_ptr->fx_media_driver_buffer, start_sector, 512, num_sectors);
    if (status == 0)
    return status;
发表于 2023-3-19 10:49:40 | 显示全部楼层
调试下,这个函数status = SD_Init();正确进入没用
 楼主| 发表于 2023-3-19 11:07:49 | 显示全部楼层
进入了。也试过在外设初始化的时候SD_Init(),一样不行
 楼主| 发表于 2023-3-19 11:25:12 | 显示全部楼层
我把工程传上来,硬汉哥抽空能帮看看嘛
ThreadX_F405RGT6+-+报错0x02.7z
2.29 MB, 下载次数: 2
发表于 2023-3-20 00:42:48 | 显示全部楼层
哲学家 发表于 2023-3-19 11:25
我把工程传上来,硬汉哥抽空能帮看看嘛
好的,今天有时间了我看下。
GMT+8, 2026-11-24 00:06 , Processed in 1.271913 second(s), 27 queries .
