查看: 2522|回复: 2
[IAR] IAR的map文件中P1,P2,A1,A2的含义
发表于 2023-3-7 02:04:56 | 显示全部楼层 |阅读模式
More we do, more we can do.
发表于 2023-3-7 09:42:32 | 显示全部楼层
看了原文还是没说透,或者说:解释了A#和P#,但是icf背景知识没提。
The "A#" stands for a memory area where the contents are absolutely placed.
The "P#" stands for placement of sections and blocks in a specific region.
固件開發工程師
发表于 2023-3-17 15:06:46 | 显示全部楼层
学习了,官网提供的Linker相关的FAQ还是挺丰富的。
https://www.iar.com/knowledge/support/technical-notes/linker/
GMT+8, 2026-11-24 12:56 , Processed in 0.337963 second(s), 28 queries .
