查看: 3122|回复: 1
[ThreadX全家桶] ThreadX滴答定时器汇编代码和C代码实现
发表于 2023-2-18 03:04:15 | 显示全部楼层 |阅读模式
汇编:
[Asm] 纯文本查看 复制代码
/*       Copyright (c) Microsoft Corporation. All rights reserved.        */
/*       This software is licensed under the Microsoft Software License   */
/*       Terms for Microsoft Azure RTOS. Full text of the license can be  */
/*       found in the LICENSE file at [url]https://aka.ms/AzureRTOS_EULA[/url]       */
/*       and in the root directory of this software.                      */
/** ThreadX Component                                                     */
/**   Timer                                                               */
    IMPORT      _tx_timer_time_slice
    IMPORT      _tx_timer_system_clock
    IMPORT      _tx_timer_current_ptr
    IMPORT      _tx_timer_list_start
    IMPORT      _tx_timer_list_end
    IMPORT      _tx_timer_expired_time_slice
    IMPORT      _tx_thread_time_slice
    IMPORT      _tx_timer_expiration_process
    IMPORT      _tx_thread_preempt_disable
    IMPORT      _tx_thread_current_ptr
    IMPORT      _tx_thread_execute_ptr
    AREA ||.text||, CODE, READONLY
    PRESERVE8
/*  FUNCTION                                               RELEASE        */
/*    _tx_timer_interrupt                              Cortex-M7/AC5      */
/*                                                           6.1.7        */
/*  AUTHOR        */
/*    Scott Larson, Microsoft Corporation                                 */
/*  DESCRIPTION                                                           */
/*    This function processes the hardware timer interrupt.  This         */
/*    processing includes incrementing the system clock and checking for  */
/*    time slice and/or timer expiration.  If either is found, the        */
/*    expiration functions are called.                                    */
/*  INPUT        */
/*    None        */
/*  OUTPUT        */
/*    None        */
/*  CALLS        */
/*    _tx_timer_expiration_process          Timer expiration processing   */
/*    _tx_thread_time_slice                 Time slice interrupted thread */
/*  CALLED BY                                                             */
/*    interrupt vector                                                    */
/*  RELEASE HISTORY                                                       */
/*    DATE              NAME                      DESCRIPTION             */
/*  06-02-2021     Scott Larson             Initial Version 6.1.7         */
// VOID   _tx_timer_interrupt(VOID)
    EXPORT  _tx_timer_interrupt
_tx_timer_interrupt
    /* Upon entry to this routine, it is assumed that the compiler scratch registers are available
       for use.  */
    /* Increment the system clock.  */
    // _tx_timer_system_clock++;
    LDR     r1, =_tx_timer_system_clock             // Pickup address of system clock
    LDR     r0, [r1, #0]                            // Pickup system clock
    ADD     r0, r0, #1                              // Increment system clock
    STR     r0, [r1, #0]                            // Store new system clock
    /* Test for time-slice expiration.  */
    // if (_tx_timer_time_slice)
    LDR     r3, =_tx_timer_time_slice               // Pickup address of time-slice
    LDR     r2, [r3, #0]                            // Pickup time-slice
    CBZ     r2, __tx_timer_no_time_slice            // Is it non-active?
                                                    // Yes, skip time-slice processing
       /* Decrement the time_slice.  */
       // _tx_timer_time_slice--;
    SUB     r2, r2, #1                              // Decrement the time-slice
    STR     r2, [r3, #0]                            // Store new time-slice value
       /* Check for expiration.  */
       // if (__tx_timer_time_slice == 0)
    CBNZ    r2, __tx_timer_no_time_slice            // Has it expired?
                                                    // No, skip expiration processing
       /* Set the time-slice expired flag.  */
       // _tx_timer_expired_time_slice =  TX_TRUE;
    LDR     r3, =_tx_timer_expired_time_slice       // Pickup address of expired flag
    MOV     r0, #1                                  // Build expired value
    STR     r0, [r3, #0]                            // Set time-slice expiration flag
    /* Test for timer expiration.  */
    // if (*_tx_timer_current_ptr)
    LDR     r1, =_tx_timer_current_ptr              // Pickup current timer pointer address
    LDR     r0, [r1, #0]                            // Pickup current timer
    LDR     r2, [r0, #0]                            // Pickup timer list entry
    CBZ     r2, __tx_timer_no_timer                 // Is there anything in the list?
                                                    // No, just increment the timer
        /* Set expiration flag.  */
        // _tx_timer_expired =  TX_TRUE;
    LDR     r3, =_tx_timer_expired                  // Pickup expiration flag address
    MOV     r2, #1                                  // Build expired value
    STR     r2, [r3, #0]                            // Set expired flag
    B       __tx_timer_done                         // Finished timer processing
    // else
__tx_timer_no_timer
        /* No timer expired, increment the timer pointer.  */
        // _tx_timer_current_ptr++;
    ADD     r0, r0, #4                              // Move to next timer
        /* Check for wrap-around.  */
        // if (_tx_timer_current_ptr == _tx_timer_list_end)
    LDR     r3, =_tx_timer_list_end                 // Pickup addr of timer list end
    LDR     r2, [r3, #0]                            // Pickup list end
    CMP     r0, r2                                  // Are we at list end?
    BNE     __tx_timer_skip_wrap                    // No, skip wrap-around logic
            /* Wrap to beginning of list.  */
            // _tx_timer_current_ptr =  _tx_timer_list_start;
    LDR     r3, =_tx_timer_list_start               // Pickup addr of timer list start
    LDR     r0, [r3, #0]                            // Set current pointer to list start
    STR     r0, [r1, #0]                            // Store new current timer pointer
__tx_timer_done
    /* See if anything has expired.  */
    // if ((_tx_timer_expired_time_slice) || (_tx_timer_expired))
    LDR     r3, =_tx_timer_expired_time_slice       // Pickup addr of expired flag
    LDR     r2, [r3, #0]                            // Pickup time-slice expired flag
    CBNZ    r2, __tx_something_expired              // Did a time-slice expire?
                                                    // If non-zero, time-slice expired
    LDR     r1, =_tx_timer_expired                  // Pickup addr of other expired flag
    LDR     r0, [r1, #0]                            // Pickup timer expired flag
    CBZ     r0, __tx_timer_nothing_expired          // Did a timer expire?
                                                    // No, nothing expired
    STMDB   sp!, {r0, lr}                           // Save the lr register on the stack
                                                    //   and save r0 just to keep 8-byte alignment
    /* Did a timer expire?  */
    // if (_tx_timer_expired)
    LDR     r1, =_tx_timer_expired                  // Pickup addr of expired flag
    CBZ     r0, __tx_timer_dont_activate            // Check for timer expiration
                                                    // If not set, skip timer activation
        /* Process timer expiration.  */
        // _tx_timer_expiration_process();
    BL      _tx_timer_expiration_process            // Call the timer expiration handling routine
    /* Did time slice expire?  */
    // if (_tx_timer_expired_time_slice)
    LDR     r3, =_tx_timer_expired_time_slice       // Pickup addr of time-slice expired
    LDR     r2, [r3, #0]                            // Pickup the actual flag
    CBZ     r2, __tx_timer_not_ts_expiration        // See if the flag is set
                                                    // No, skip time-slice processing
        /* Time slice interrupted thread.  */
        // _tx_thread_time_slice();
    BL      _tx_thread_time_slice                   // Call time-slice processing
    LDR     r0, =_tx_thread_preempt_disable         // Build address of preempt disable flag
    LDR     r1, [r0]                                // Is the preempt disable flag set?
    CBNZ    r1, __tx_timer_skip_time_slice          // Yes, skip the PendSV logic
    LDR     r0, =_tx_thread_current_ptr             // Build current thread pointer address
    LDR     r1, [r0]                                // Pickup the current thread pointer
    LDR     r2, =_tx_thread_execute_ptr             // Build execute thread pointer address
    LDR     r3, [r2]                                // Pickup the execute thread pointer
    LDR     r0, =0xE000ED04                         // Build address of control register
    LDR     r2, =0x10000000                         // Build value for PendSV bit
    CMP     r1, r3                                  // Are they the same?
    BEQ     __tx_timer_skip_time_slice              // If the same, there was no time-slice performed
    STR     r2, [r0]                                // Not the same, issue the PendSV for preemption
    LDMIA   sp!, {r0, lr}                           // Recover lr register (r0 is just there for
                                                    //   the 8-byte stack alignment
    DSB                                             // Complete all memory access
    BX      lr                                      // Return to caller
    ALIGN
    LTORG
    END
C实现:
/**   Timer                                                               */
    PRESERVE8
/*                                                           6.1.7        */
/*  AUTHOR        */
/*  DESCRIPTION                                                           */
/*  INPUT        */
/*    None        */
/*  OUTPUT        */
/*    None        */
/*  CALLS        */
/*  CALLED BY                                                             */
       for use.  */
发表于 2023-2-20 11:24:35 | 显示全部楼层
GMT+8, 2026-11-23 23:58 , Processed in 0.339652 second(s), 24 queries .
