查看: 2233|回复: 0
[KiCad] 适用于 CI/CD 的 KiCad 自动化脚本的 Docker 镜像
发表于 2023-2-14 11:03:50 | 显示全部楼层 |阅读模式
https://github.com/INTI-CMNB/kicad_auto
kicad_auto
Docker image for KiCad automation scripts suitable for CI/CD
The main objetive is to use it as a base for [color=var(--color-accent-fg)]KiCad automation in CI/CD environments.
The images are uploaded to [color=var(--color-accent-fg)]Docker Hub and GitHub: [color=var(--color-accent-fg)]Compatibility names, [color=var(--color-accent-fg)]KiCad 5 and [color=var(--color-accent-fg)]KiCad 6.
This image is based on [color=var(--color-accent-fg)]setsoft/kicad_debian and adds some automation tools to it:
  • [color=var(--color-accent-fg)]KiBot generate gerbers, drill, position files, etc.
  • [color=var(--color-accent-fg)]KiAuto runs DRC/ERC, prints schematics, PCB, etc.
  • [color=var(--color-accent-fg)]KiBoM generates HTML and CSV BoMs
  • [color=var(--color-accent-fg)]InteractiveHtmlBom generates interactive HTML BoMs
  • [color=var(--color-accent-fg)]PcbDraw generates 2D renders of the PCB
  • [color=var(--color-accent-fg)]KiCost generates BoMs with prices
  • [color=var(--color-accent-fg)]KiCad Git filters helps to reduce unneeded commits for KiCad files when using git
  • [color=var(--color-accent-fg)]KiCad PCB diff a tool to see differences between PCBs, can be used as git plugin
export USER_ID=$(id -u)
export GROUP_ID=$(id -g)
export WORKDIR=RELATIVE_PATH_TO_KICAD_PROJECTS
export SUBDIR=SUBDIR_INSIDE_WORKDIR
docker run --rm -it -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY \
    -v $(pwd)/$WORKDIR:/home/$USER/workdir \
    --user $USER_ID:$GROUP_ID \
    --env NO_AT_BRIDGE=1 \
    --workdir="/home/$USER" \
    --volume="/etc/group:/etc/group:ro" \
    --volume="/home/$USER/.config/kicad:/home/$USER/.config/kicad:rw" \
    --volume="/home/$USER/.cache/kicad:/home/$USER/.cache/kicad:rw" \
    --volume="/etc/passwd:/etc/passwd:ro" \
    --volume="/etc/shadow:/etc/shadow:ro" \
    setsoft/kicad_auto:10.3-5.1.5 /bin/bash -c "cd workdir/$SUBDIR; kiplot"
GMT+8, 2026-11-22 22:45 , Processed in 1.291568 second(s), 22 queries .
