查看: 1858|回复: 1
[μCOS-III] 请教ucosiii的FPU移植问题
发表于 2023-1-6 12:31:15 | 显示全部楼层 |阅读模式
我在看ucosiii的3.08版本的模板移植是如下
CPU_STK  *OSTaskStkInit (OS_TASK_PTR    p_task,
                         void          *p_arg,
                         CPU_STK       *p_stk_base,
                         CPU_STK       *p_stk_limit,
                         CPU_STK_SIZE   stk_size,
                         OS_OPT         opt)
    CPU_STK    *p_stk;
    (void)opt;                                                  /* 'opt' is not used, prevent warning                   */
    p_stk = &p_stk_base[stk_size];                              /* Load stack pointer                                   */
        /* Align the stack to 8-bytes.                          */
    p_stk = (CPU_STK *)((CPU_STK)(p_stk) & 0xFFFFFFF8u);
        /* Registers stacked as if auto-saved on exception      */
#if (OS_CPU_ARM_FP_EN > 0u)                                     /* FPU auto-saved registers.                            */
     --p_stk;
    *(--p_stk) = (CPU_STK)0x02000000u;                          /* FPSCR                                                */
        /* Initialize S0-S15 floating point registers           */
    *(--p_stk) = (CPU_STK)0x41700000u;                          /* S15                                                  */
    *(--p_stk) = (CPU_STK)0x41600000u;                          /* S14                                                  */
    *(--p_stk) = (CPU_STK)0x41500000u;                          /* S13                                                  */
    *(--p_stk) = (CPU_STK)0x41400000u;                          /* S12                                                  */
    *(--p_stk) = (CPU_STK)0x41300000u;                          /* S11                                                  */
    *(--p_stk) = (CPU_STK)0x41200000u;                          /* S10                                                  */
    *(--p_stk) = (CPU_STK)0x41100000u;                          /* S9                                                   */
    *(--p_stk) = (CPU_STK)0x41000000u;                          /* S8                                                   */
    *(--p_stk) = (CPU_STK)0x40E00000u;                          /* S7                                                   */
    *(--p_stk) = (CPU_STK)0x40C00000u;                          /* S6                                                   */
    *(--p_stk) = (CPU_STK)0x40A00000u;                          /* S5                                                   */
    *(--p_stk) = (CPU_STK)0x40800000u;                          /* S4                                                   */
    *(--p_stk) = (CPU_STK)0x40400000u;                          /* S3                                                   */
    *(--p_stk) = (CPU_STK)0x40000000u;                          /* S2                                                   */
    *(--p_stk) = (CPU_STK)0x3F800000u;                          /* S1                                                   */
    *(--p_stk) = (CPU_STK)0x00000000u;                          /* S0                                                   */
#endif
    *(--p_stk) = (CPU_STK)0x01000000u;                          /* xPSR                                                 */
    *(--p_stk) = (CPU_STK)p_task;                               /* Entry Point                                          */
    *(--p_stk) = (CPU_STK)OS_TaskReturn;                        /* R14 (LR)                                             */
    *(--p_stk) = (CPU_STK)0x12121212u;                          /* R12                                                  */
    *(--p_stk) = (CPU_STK)0x03030303u;                          /* R3                                                   */
    *(--p_stk) = (CPU_STK)0x02020202u;                          /* R2                                                   */
    *(--p_stk) = (CPU_STK)p_stk_limit;                          /* R1                                                   */
    *(--p_stk) = (CPU_STK)p_arg;                                /* R0 : argument                                        */
    *(--p_stk) = (CPU_STK)0xFFFFFFEDuL;                         /* R14: EXEC_RETURN; See Note 5                         */
#else
    *(--p_stk) = (CPU_STK)0xFFFFFFFDuL;                         /* R14: EXEC_RETURN; See Note 5                         */
#endif
        /* Remaining registers saved on process stack           */
    *(--p_stk) = (CPU_STK)0x11111111uL;                         /* R11                                                  */
    *(--p_stk) = (CPU_STK)0x10101010uL;                         /* R10                                                  */
    *(--p_stk) = (CPU_STK)0x09090909uL;                         /* R9                                                   */
    *(--p_stk) = (CPU_STK)0x08080808uL;                         /* R8                                                   */
    *(--p_stk) = (CPU_STK)0x07070707uL;                         /* R7                                                   */
    *(--p_stk) = (CPU_STK)0x06060606uL;                         /* R6                                                   */
    *(--p_stk) = (CPU_STK)0x05050505uL;                         /* R5                                                   */
    *(--p_stk) = (CPU_STK)0x04040404uL;                         /* R4                                                   */
        /* Initialize S16-S31 floating point registers          */
    *(--p_stk) = (CPU_STK)0x41F80000u;                          /* S31                                                  */
    *(--p_stk) = (CPU_STK)0x41F00000u;                          /* S30                                                  */
    *(--p_stk) = (CPU_STK)0x41E80000u;                          /* S29                                                  */
    *(--p_stk) = (CPU_STK)0x41E00000u;                          /* S28                                                  */
    *(--p_stk) = (CPU_STK)0x41D80000u;                          /* S27                                                  */
    *(--p_stk) = (CPU_STK)0x41D00000u;                          /* S26                                                  */
    *(--p_stk) = (CPU_STK)0x41C80000u;                          /* S25                                                  */
    *(--p_stk) = (CPU_STK)0x41C00000u;                          /* S24                                                  */
    *(--p_stk) = (CPU_STK)0x41B80000u;                          /* S23                                                  */
    *(--p_stk) = (CPU_STK)0x41B00000u;                          /* S22                                                  */
    *(--p_stk) = (CPU_STK)0x41A80000u;                          /* S21                                                  */
    *(--p_stk) = (CPU_STK)0x41A00000u;                          /* S20                                                  */
    *(--p_stk) = (CPU_STK)0x41980000u;                          /* S19                                                  */
    *(--p_stk) = (CPU_STK)0x41900000u;                          /* S18                                                  */
    *(--p_stk) = (CPU_STK)0x41880000u;                          /* S17                                                  */
    *(--p_stk) = (CPU_STK)0x41800000u;                          /* S16                                                  */
#endif
    return (p_stk);
我在看《安富莱_STM32-V5开发板_μCOS-III教程》的FPU解决方案的代码如下:
 void *p_arg,
 OS_OPT opt)
 CPU_STK *p_stk;
 (void)opt; /* Prevent compiler warning */
 p_stk = (CPU_STK *)((CPU_STK)(p_stk) & 0xFFFFFFF8);
*--p_stk = (CPU_STK)0x01000000u; /* xPSR */
 *--p_stk = (CPU_STK)p_task; /* Entry Point */
 *--p_stk = (CPU_STK)OS_TaskReturn; /* R14 (LR) */
 *--p_stk = (CPU_STK)0x12121212u; /* R12 */
 *--p_stk = (CPU_STK)0x03030303u; /* R3 */
 *--p_stk = (CPU_STK)0x02020202u; /* R2 */
 *--p_stk = (CPU_STK)p_stk_limit; /* R1 */
 *--p_stk = (CPU_STK)p_arg; /* R0 : argument */
 *--p_stk = (CPU_STK)0x11111111u; /* R11 */
 *--p_stk = (CPU_STK)0x10101010u; /* R10 */
 *--p_stk = (CPU_STK)0x09090909u; /* R9 */
 *--p_stk = (CPU_STK)0x08080808u; /* R8 */
 *--p_stk = (CPU_STK)0x07070707u; /* R7 */
 *--p_stk = (CPU_STK)0x06060606u; /* R6 */
 *--p_stk = (CPU_STK)0x05050505u; /* R5 */
 *--p_stk = (CPU_STK)0x04040404u; /* R4 */
 *--p_stk = (CPU_STK)0xFFFFFFFDUL; (1)
return (p_stk);
为什么在《安富莱_STM32-V5开发板_μCOS-III教程》书中的处理方法和ucos3.08模板的处理方法不一样?
发表于 2023-1-7 00:46:13 | 显示全部楼层
下面那个代码是我们自己做的一个FPU实现方案,早期的uCOS-III的FPU问题比较多,所以自己做了个实现。
3.08那个是uCOS官方后来推出了新方案。
GMT+8, 2026-11-23 23:59 , Processed in 0.665202 second(s), 24 queries .
