查看: 2320|回复: 8
[技术讨论] GD32F450IIH6 移植完驱动后网口不工作
发表于 2022-12-29 16:03:42 | 显示全部楼层 |阅读模式
GD32F450IIH6 移植完驱动后网口不工作,求助!
发表于 2022-12-29 16:52:15 | 显示全部楼层
这个GD官方好像有例子的,他们官方的例子有测试过没
 楼主| 发表于 2022-12-30 17:01:00 | 显示全部楼层
就是按照GD官网的例子移植的,但是好像不行 IC我用的YT8512H,求助下.
另外我想问下GD32F107能支持SPI Nand flash吗?
发表于 2022-12-31 01:49:44 | 显示全部楼层
另外我想问下GD32F107能支持SPI Nan ...
1、方便先用个跟官方评估版一样的phy,成功了,再试试你的,这样还方便排查问题。
2、没问题,只是NAND管理算法需要你移植支持的文件系统才行。
发表于 2024-6-4 11:56:34 | 显示全部楼层
大佬成功了吗?  我现在在移植到YT8512 也遇到了麻烦
发表于 2024-6-12 11:36:23 | 显示全部楼层
* @file
* Ethernet Interface for standalone applications (without RTOS)
* Copyright (c) 2001-2004 Swedish Institute of Computer Science.
* All rights reserved.
* Redistribution and use in source and binary forms, with or without modification,
* are permitted provided that the following conditions are met:
* 1. Redistributions of source code must retain the above copyright notice,
*    this list of conditions and the following disclaimer.
* 2. Redistributions in binary form must reproduce the above copyright notice,
*    this list of conditions and the following disclaimer in the documentation
*    and/or other materials provided with the distribution.
* 3. The name of the author may not be used to endorse or promote products
*    derived from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
* WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT
* SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
* OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
* IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
* OF SUCH DAMAGE.
* This file is part of the lwIP TCP/IP stack.
* Author: Adam Dunkels <adam@sics.se>
#include "lwip/mem.h"
#include "netif/etharp.h"
#include "ethernetif.h"
#include "gd32f4xx_enet.h"
#include "main_lwip.h"
#include <string.h>
/* network interface name */
#define IFNAME0 'G'
#define IFNAME1 'D'
/* ENET RxDMA/TxDMA descriptor */
extern enet_descriptors_struct  rxdesc_tab[ENET_RXBUF_NUM], txdesc_tab[ENET_TXBUF_NUM];
/* ENET receive buffer  */
extern uint8_t rx_buff[ENET_RXBUF_NUM][ENET_RXBUF_SIZE];
/* ENET transmit buffer */
extern uint8_t tx_buff[ENET_TXBUF_NUM][ENET_TXBUF_SIZE];
/*global transmit and receive descriptors pointers */
extern enet_descriptors_struct  *dma_current_txdesc;
extern enet_descriptors_struct  *dma_current_rxdesc;
/* preserve another ENET RxDMA/TxDMA ptp descriptor for normal mode */
enet_descriptors_struct  ptp_txstructure[ENET_TXBUF_NUM];
enet_descriptors_struct  ptp_rxstructure[ENET_RXBUF_NUM];
* In this function, the hardware should be initialized.
* Called from ethernetif_init().
* @param netif the already initialized lwip network interface structure
*        for this ethernetif
static void low_level_init(struct netif *netif)
#ifdef CHECKSUM_BY_HARDWARE
    int i;
#endif /* CHECKSUM_BY_HARDWARE */
    /* set MAC hardware address length */
    netif->hwaddr_len = ETHARP_HWADDR_LEN;
    /* set MAC hardware address */
    netif->hwaddr[0] =  MAC_ADDR0;
    netif->hwaddr[1] =  MAC_ADDR1;
    netif->hwaddr[2] =  MAC_ADDR2;
    netif->hwaddr[3] =  MAC_ADDR3;
    netif->hwaddr[4] =  MAC_ADDR4;
    netif->hwaddr[5] =  MAC_ADDR5;
    /* initialize MAC address in ethernet MAC */
    enet_mac_address_set(ENET_MAC_ADDRESS0, netif->hwaddr);
    /* maximum transfer unit */
    netif->mtu = 1500;
    /* device capabilities */
    /* don't set NETIF_FLAG_ETHARP if this device is not an ethernet one */
    netif->flags = NETIF_FLAG_BROADCAST | NETIF_FLAG_ETHARP | NETIF_FLAG_LINK_UP;
    /* initialize descriptors list: chain/ring mode */
#ifdef SELECT_DESCRIPTORS_ENHANCED_MODE
    enet_ptp_enhanced_descriptors_chain_init(ENET_DMA_TX);
    enet_ptp_enhanced_descriptors_chain_init(ENET_DMA_RX);
#else
    enet_descriptors_chain_init(ENET_DMA_TX);
    enet_descriptors_chain_init(ENET_DMA_RX);
//    enet_descriptors_ring_init(ENET_DMA_TX);
//    enet_descriptors_ring_init(ENET_DMA_RX);
#endif /* SELECT_DESCRIPTORS_ENHANCED_MODE */
    /* enable ethernet Rx interrrupt */
    {   int i;
        for(i=0; i<ENET_RXBUF_NUM; i++){
           enet_rx_desc_immediate_receive_complete_interrupt(&rxdesc_tab);
    /* enable the TCP, UDP and ICMP checksum insertion for the Tx frames */
    for(i=0; i < ENET_TXBUF_NUM; i++){
        enet_transmit_checksum_config(&txdesc_tab, ENET_CHECKSUM_TCPUDPICMP_FULL);
    /* note: TCP, UDP, ICMP checksum checking for received frame are enabled in DMA config */
    /* enable MAC and DMA transmission and reception */
    enet_enable();
* This function should do the actual transmission of the packet. The packet is
* contained in the pbuf that is passed to the function. This pbuf
* might be chained.
* @param netif the lwip network interface structure for this ethernetif
* @param p the MAC packet to send (e.g. IP packet including MAC addresses and type)
* @return ERR_OK if the packet could be sent
*         an err_t value if the packet couldn't be sent
* @note Returning ERR_MEM here if a DMA queue of your MAC is full can lead to
*       strange results. You might consider waiting for space in the DMA queue
*       to become availale since the stack doesn't retry to send a packet
*       dropped because of memory failure (except for the TCP timers).
static err_t low_level_output(struct netif *netif, struct pbuf *p)
    struct pbuf *q;
    int framelength = 0;
    uint8_t *buffer;
    while((uint32_t)RESET != (dma_current_txdesc->status & ENET_TDES0_DAV)){
    buffer = (uint8_t *)(enet_desc_information_get(dma_current_txdesc, TXDESC_BUFFER_1_ADDR));
    /* copy frame from pbufs to driver buffers */
    for(q = p; q != NULL; q = q->next){
        memcpy((uint8_t *)&buffer[framelength], q->payload, q->len);
        framelength = framelength + q->len;
    /* note: padding and CRC for transmitted frame
       are automatically inserted by DMA */
    /* transmit descriptors to give to DMA */
    ENET_NOCOPY_PTPFRAME_TRANSMIT_ENHANCED_MODE(framelength, NULL);
#else
    ENET_NOCOPY_FRAME_TRANSMIT(framelength);
    return ERR_OK;
* Should allocate a pbuf and transfer the bytes of the incoming
* packet from the interface into the pbuf.
* @return a pbuf filled with the received packet (including MAC header)
*         NULL on memory error
static struct pbuf * low_level_input(struct netif *netif)
    struct pbuf *p, *q;
    u16_t len;
    int l =0;
    uint8_t *buffer;
    p = NULL;
    /* obtain the size of the packet and put it into the "len" variable. */
    len = enet_desc_information_get(dma_current_rxdesc, RXDESC_FRAME_LENGTH);
    buffer = (uint8_t *)(enet_desc_information_get(dma_current_rxdesc, RXDESC_BUFFER_1_ADDR));
    /* we allocate a pbuf chain of pbufs from the Lwip buffer pool */
    p = pbuf_alloc(PBUF_RAW, len, PBUF_POOL);
    /* copy received frame to pbuf chain */
    if (p != NULL){
        for (q = p; q != NULL; q = q->next){
            memcpy((uint8_t *)q->payload, (u8_t*)&buffer[l], q->len);
            l = l + q->len;
    ENET_NOCOPY_PTPFRAME_RECEIVE_ENHANCED_MODE(NULL);
#else
    ENET_NOCOPY_FRAME_RECEIVE();
    return p;
* This function should be called when a packet is ready to be read
* from the interface. It uses the function low_level_input() that
* should handle the actual reception of bytes from the network
* interface. Then the type of the received packet is determined and
* the appropriate input function is called.
#if 1
err_t ethernetif_input(struct netif *netif)
    err_t err;
    struct pbuf *p;
    /* move received packet into a new pbuf */
    p = low_level_input(netif);
    /* no packet could be read, silently ignore this */
    if (p == NULL)
                        return ERR_MEM;
    /* entry point to the LwIP stack */
    err = netif->input(p, netif);
    if (err != ERR_OK){
        LWIP_DEBUGF(NETIF_DEBUG, ("ethernetif_input: IP input error\n"));
        pbuf_free(p);
        p = NULL;
    return err;
#else
        err_t err;
        struct pbuf *p;
        p=low_level_input(netif);
        while(p)
                err=netif->input(p, netif);
                if(err!=ERR_OK)
                        LWIP_DEBUGF(NETIF_DEBUG,("ethernetif_input: IP input error\n"));
                        pbuf_free(p);
                        p = NULL;
        return err;
#endif
* Should be called at the beginning of the program to set up the
* network interface. It calls the function low_level_init() to do the
* actual setup of the hardware.
* This function should be passed as a parameter to netif_add().
* @return ERR_OK if the loopif is initialized
*         ERR_MEM if private data couldn't be allocated
*         any other err_t on error
err_t ethernetif_init(struct netif *netif)
    LWIP_ASSERT("netif != NULL", (netif != NULL));
#if LWIP_NETIF_HOSTNAME
    /* Initialize interface hostname */
    netif->hostname = "SmartControl_lwip";
#endif /* LWIP_NETIF_HOSTNAME */
    netif->name[0] = IFNAME0;
    netif->name[1] = IFNAME1;
    /* We directly use etharp_output() here to save a function call.
     * You can instead declare your own function an call etharp_output()
     * from it if you have to do some checks before sending (e.g. if link
     * is available...) */
    netif->output = etharp_output;
    netif->linkoutput = low_level_output;
    /* initialize the hardware */
    low_level_init(netif);
    return ERR_OK;
发表于 2024-6-12 11:37:03 | 显示全部楼层
/****************************************Copyright (c)****************************************************
**--------------File Info---------------------------------------------------------------------------------
** File name:               bsp_eth.c
** Descriptions:            ETH  Config
** IC MODEL:                                GD32F450Z
** Created by:              vim
** Created date:            2023-05-16
** Version:                 v1.0
** Descriptions:            The original version
** Modified by:
** Modified date:
** Version:
** Descriptions:
#include "bsp.h"
#include "lwipopts.h"
#include "netif/ethernet.h"
#define USE_ENET_INTERRUPT
extern struct netif gnetif;
#ifdef USE_ENET_INTERRUPT
static __IO uint8_t ethflag = 0;
#endif /* USE_ENET_INTERRUPT */
static __IO uint32_t enet_init_status = 0;
*        函 数 名: ETH_GPIO_Config_RMII
*        功能说明: 配置GD32F4 ETH (RMII Mode)
*        形    参: 无
*        返 回 值: 无
static void ETH_GPIO_Config_RMII(void)
                rcu_periph_clock_enable(RCU_GPIOA);
                rcu_periph_clock_enable(RCU_GPIOB);
                rcu_periph_clock_enable(RCU_GPIOC);
                rcu_periph_clock_enable(RCU_GPIOE);
                /* enable SYSCFG clock */
    rcu_periph_clock_enable(RCU_SYSCFG);
                syscfg_enet_phy_interface_config(SYSCFG_ENET_PHY_RMII);
                gpio_mode_set(GPIOE,GPIO_MODE_OUTPUT,GPIO_PUPD_NONE,GPIO_PIN_11);           //配置为输出模式 浮空模式
                gpio_output_options_set(GPIOE,GPIO_OTYPE_PP,GPIO_OSPEED_50MHZ,GPIO_PIN_11); //配置为推挽输出 50M
                /* PA1: ETH_RMII_REF_CLK */
    gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_1);
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_MAX, GPIO_PIN_1);
    /* PA2: ETH_MDIO */
    gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_2);
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_MAX, GPIO_PIN_2);
    /* PA7: ETH_RMII_CRS_DV */
    gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_7);
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_MAX, GPIO_PIN_7);
    gpio_af_set(GPIOA, GPIO_AF_11, GPIO_PIN_1);
    gpio_af_set(GPIOA, GPIO_AF_11, GPIO_PIN_2);
    gpio_af_set(GPIOA, GPIO_AF_11, GPIO_PIN_7);
    /* PB11: ETH_RMII_TX_EN */
    gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_11);
    gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_MAX, GPIO_PIN_11);
    /* PB12: ETH_RMII_TXD0 */
    gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_12);
    gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_MAX, GPIO_PIN_12);
    /* PB13: ETH_RMII_TXD1 */
    gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_13);
    gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_MAX, GPIO_PIN_13);
    gpio_af_set(GPIOB, GPIO_AF_11, GPIO_PIN_11);
    gpio_af_set(GPIOB, GPIO_AF_11, GPIO_PIN_12);
    gpio_af_set(GPIOB, GPIO_AF_11, GPIO_PIN_13);
    /* PC1: ETH_MDC */
    gpio_mode_set(GPIOC, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_1);
    gpio_output_options_set(GPIOC, GPIO_OTYPE_PP, GPIO_OSPEED_MAX, GPIO_PIN_1);
    /* PC4: ETH_RMII_RXD0 */
    gpio_mode_set(GPIOC, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_4);
    gpio_output_options_set(GPIOC, GPIO_OTYPE_PP, GPIO_OSPEED_MAX, GPIO_PIN_4);
    /* PC5: ETH_RMII_RXD1 */
    gpio_mode_set(GPIOC, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_5);
    gpio_output_options_set(GPIOC, GPIO_OTYPE_PP, GPIO_OSPEED_MAX, GPIO_PIN_5);
    gpio_af_set(GPIOC, GPIO_AF_11, GPIO_PIN_1);
    gpio_af_set(GPIOC, GPIO_AF_11, GPIO_PIN_4);
    gpio_af_set(GPIOC, GPIO_AF_11, GPIO_PIN_5);
*        函 数 名: ETH_MAC_DMAConfig
*        功能说明: 配置GD32F4 ETH MAC/DMA
*        形    参: 无
*        返 回 值: 无
static void ETH_MAC_DMAConfig(void)
        ErrStatus reval_state = ERROR;
        /* enable ethernet clock  */
  rcu_periph_clock_enable(RCU_ENET);
        rcu_periph_clock_enable(RCU_ENETTX);
  rcu_periph_clock_enable(RCU_ENETRX);
        /* reset ethernet on AHB bus */
  enet_deinit();
        reval_state = enet_software_reset();
  if(ERROR == reval_state) {
      while(1) {}
        /* configure the parameters which are usually less cared for enet initialization */
        //  enet_initpara_config(HALFDUPLEX_OPTION, ENET_CARRIERSENSE_ENABLE|ENET_RECEIVEOWN_ENABLE|ENET_RETRYTRANSMISSION_DISABLE|ENET_BACKOFFLIMIT_10|ENET_DEFERRALCHECK_DISABLE);
        //  enet_initpara_config(DMA_OPTION, ENET_FLUSH_RXFRAME_ENABLE|ENET_SECONDFRAME_OPT_ENABLE|ENET_NORMAL_DESCRIPTOR);
    enet_init_status = enet_init(ENET_100M_FULLDUPLEX, ENET_AUTOCHECKSUM_DROP_FAILFRAMES, ENET_BROADCAST_FRAMES_PASS);
#else
    enet_init_status = enet_init(ENET_100M_FULLDUPLEX, ENET_NO_AUTOCHECKSUM, ENET_BROADCAST_FRAMES_PASS);
*        函 数 名: bsp_ETH_Init
*        形    参: 无
*        返 回 值: 无
void bsp_ETH_Init(void)
        uint16_t count = 5000;
    nvic_irq_enable(ENET_IRQn, 2, 0);
        ETH_GPIO_Config_RMII();
        //PHY Reset
        gpio_bit_reset(GPIOE, GPIO_PIN_11);
        while(count--)
        gpio_bit_set(GPIOE, GPIO_PIN_11);
        ETH_MAC_DMAConfig();
        if(0 == enet_init_status)
                        while(1) {
    enet_interrupt_enable(ENET_DMA_INT_NIE);
    enet_interrupt_enable(ENET_DMA_INT_RIE);
uint8_t bsp_Get_ethflag(void)
        return ethflag;
void bsp_Set_ethflag(uint8_t val)
        ethflag = val;
    \brief      this function handles ethernet interrupt request
    \param[in]  none
    \param[out] none
    \retval     none
void ENET_IRQHandler(void)
    uint32_t reval;
        /* handles all the received frames */
    do{
        reval = enet_rxframe_size_get();
        if(reval > 1){
            //调用网卡接收函数
                                                ethernetif_input(&gnetif);
    }while(reval != 0);
                /* clear the enet DMA Rx interrupt pending bits */
    enet_interrupt_flag_clear(ENET_DMA_INT_FLAG_RS_CLR);
    enet_interrupt_flag_clear(ENET_DMA_INT_FLAG_NI_CLR);
/******************************************** (END OF FILE) ************************************************/
参与人数 1金币 +20 收起 理由
夜游神 + 20 很给力!
发表于 2024-6-12 11:39:28 | 显示全部楼层
以太网PHY MAC ETH:
ETH_RMII_RXD0---PC4
ETH_RMII_RXD1---PC5
ETH_RMII_TXC---PA1
ETH_RMII_TXD0---PB12
ETH_RMII_TXD1---PB13
ETH_RMII_TX_EN---PB11
RESET---PE11
ETH_MDC---PC1
ETH_MDIO---PA2
CRS/CRSDV---ETH_RMII_CRS_DV PA7
发表于 2024-6-12 16:08:42 | 显示全部楼层
GMT+8, 2026-11-22 15:15 , Processed in 1.077835 second(s), 25 queries .
