查看: 7602|回复: 5
[有问必答] 配置定时器中断的程序
发表于 2015-7-28 17:45:25 | 显示全部楼层 |阅读模式
麻烦问一下,有没有配置定时器中断的程序,感谢感谢
 楼主| 发表于 2015-7-28 18:04:10 | 显示全部楼层
TIM_TimeBaseStructure.TIM_Period = 500-1;
    TIM_TimeBaseStructure.TIM_Prescaler =8400-1;
    TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;//ÏòÉϼÆÊýģʽ
    TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
 楼主| 发表于 2015-7-28 18:04:31 | 显示全部楼层
麻烦问一下,如何配置1ms的中断啊,新手
发表于 2015-7-29 08:25:57 | 显示全部楼层
        system_stm32f4xx.c 文件中 void SetSysClock(void) 函数对时钟的配置如下:
        HCLK = SYSCLK / 1     (AHB1Periph)
        PCLK2 = HCLK / 2      (APB2Periph)
        PCLK1 = HCLK / 4      (APB1Periph)
        因为APB1 prescaler != 1, 所以 APB1上的TIMxCLK = PCLK1 x 2 = SystemCoreClock / 2;
        因为APB2 prescaler != 1, 所以 APB2上的TIMxCLK = PCLK2 x 2 = SystemCoreClock;
        APB1 定时器有 TIM2, TIM3 ,TIM4, TIM5, TIM6, TIM7, TIM12, TIM13,TIM14
        APB2 定时器有 TIM1, TIM8 ,TIM9, TIM10, TIM11
       TIM8 更新周期是 = TIM8CLK / (TIM_Period + 1)/(TIM_Prescaler + 1)
       根据需要设置TIM_Period 和TIM_Prescaler 的参数即可
void TIM8_MeasureConfig(void)
    TIM_TimeBaseInitTypeDef TIM_BaseInitStructure;
    NVIC_InitTypeDef NVIC_InitStructure;
    /* Enable the TIM8 gloabal Interrupt */
    NVIC_InitStructure.NVIC_IRQChannel = TIM8_UP_TIM13_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
    /* 开启时钟 */
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM8, ENABLE);
    /* 定时器配置 */
    TIM_DeInit(TIM8);
    TIM_BaseInitStructure.TIM_Period = 84*1024; ------------》设置参数
    TIM_BaseInitStructure.TIM_Prescaler = 0;  ------------》设置参数
    TIM_BaseInitStructure.TIM_ClockDivision = 0;
    TIM_BaseInitStructure.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_TimeBaseInit(TIM8, &TIM_BaseInitStructure);
    TIM_Cmd(TIM8, ENABLE);
    TIM_ITConfig(TIM8, TIM_IT_Update, ENABLE);
void TIM8_UP_TIM13_IRQHandler(void)
    if (TIM_GetITStatus(TIM8, TIM_IT_Update) != RESET)
        TIM_ClearITPendingBit(TIM8, TIM_IT_Update);
发表于 2015-7-29 10:33:06 | 显示全部楼层
eric2013:/*-----------------------------------------------------------------------
....... (2015-07-29 08:25)
定时器的参数好象是16位的,84*1024超过了。
发表于 2015-7-29 14:48:46 | 显示全部楼层
回 mcza30 的帖子
mcza30:TIM_BaseInitStructure.TIM_Period = 84*1024; ------------》设置参数
定时器的参数好象是16位的,84*1024超过了。 (2015-07-29 10:33)
我是举个例子。的确是超了[s:142]
GMT+8, 2026-11-28 13:26 , Processed in 1.066637 second(s), 24 queries .
