查看: 2130|回复: 0
[Lua] H7-TOOL的LUA操作Cache条件编译方法,实测好用(2022-12-24)
发表于 2022-12-24 00:40:19 | 显示全部楼层 |阅读模式
通过下面方法操作即可,用于RTOS Trace功能实测,好用
if (EnableCacheClean == 1) then  -- 条件设置,根据条件选择执行的函数
  function CacheClean(addr)
    --0xE000ED00
    --__OM  uint32_t ICIMVAU;                /*!< Offset: 0x258 ( /W)  I-Cache Invalidate by MVA to PoU */
    --__OM  uint32_t DCIMVAC;                /*!< Offset: 0x25C ( /W)  D-Cache Invalidate by MVA to PoC */
   -- __OM  uint32_t DCISW;                  /*!< Offset: 0x260 ( /W)  D-Cache Invalidate by Set-way */
   -- __OM  uint32_t DCCMVAU;                /*!< Offset: 0x264 ( /W)  D-Cache Clean by MVA to PoU */
   -- __OM  uint32_t DCCMVAC;                /*!< Offset: 0x268 ( /W)  D-Cache Clean by MVA to PoC */
   -- __OM  uint32_t DCCSW;                  /*!< Offset: 0x26C ( /W)  D-Cache Clean by Set-way */
    --__OM  uint32_t DCCIMVAC;               /*!< Offset: 0x270 ( /W)  D-Cache Clean and Invalidate by MVA to PoC */
   --__OM  uint32_t DCCISW;                 /*!< Offset: 0x274 ( /W)  D-Cache Clean and Invalidate by Set-way */
   pg_write32(0xE000EF68, addr)
  end
  function CacheClean() end
end
GMT+8, 2026-10-23 09:00 , Processed in 0.188044 second(s), 24 queries .
