查看: 7634|回复: 11
[MDK] MDK的target options各个选项的含义
发表于 2015-7-28 11:56:01 | 显示全部楼层 |阅读模式
Listing (Keil)
μVision creates several listing files that can be configured in this dialogpage. Refer to [url=">File Types for a list oflisting files.<dt class=]Select Folder for Listings...Select a folder where listing files are stored.Page WidthSpecify the number of characters per line for the listing file.Page LengthSpecify the number of lines per page for the listing files.
C Compiler Listing
Creates listing files for the C source files.ConditionalInclude un-compiled conditional code in the listing file.SymbolsInclude symbol information in the listing file.#include FilesInsert text from the include files in the listing file.Assembly CodeInsert the generated assembly code in the listing file.
C Preprocessor Listing
Instructs the compiler to produce a preprocessor listing. Macrocalls are expanded and comments are deleted.
Assembler Listing
Create listing files for the assembly source files in the projecttarget.ConditionalInclude un-compiled conditional code in the listing file.SymbolsInclude symbol information in the listing file.MacrosSpecify how macros are listed in the listing file.CrossReferenceInclude a cross reference table of symbols in the listing file.
Linker Listing
发表于 2015-7-29 10:52:34 | 显示全部楼层
map文件信息多,很长,看起来比较花眼。。。。
 楼主| 发表于 2015-7-29 11:18:15 | 显示全部楼层
回 caicaptain2 的帖子
caicaptain2:map文件信息多,很长,看起来比较花眼。。。。 (2015-07-29 10:52)
这两天正在做第11期入门视频教程,讲解下这个map文件和htm文件,这方便的介绍资料的确比较少。
发表于 2020-4-17 09:44:32 | 显示全部楼层
请问安装好MDK5后,按教程配置Target,Target界面只有Operatingsystem选项,怎么解决?
 楼主| 发表于 2020-4-17 10:18:44 | 显示全部楼层
发个截图看下。
发表于 2020-4-17 13:07:46 | 显示全部楼层
软件截图已发,谢谢你
 楼主| 发表于 2020-4-17 13:15:24 | 显示全部楼层
可乐可乐 发表于 2020-4-17 13:07
软件截图已发,谢谢你
感觉是没有安装好,换个盘符,重新安装下看看。
下载我这里面的MDK5.27:
【安富莱】MDK5.29和各种软件包镜像下载(2020-04-14)
https://forum.anfulai.cn/forum.p ... 6992&fromuid=58
发表于 2020-4-17 14:41:38 | 显示全部楼层
下载我这里面的MDK5.27:
谢谢,已安装成功。目前在学习STM32H7,要使用JLINK V9 或V10.  按照教程对JLINK  V8固件进行升级,升级后还是V8。如何达到V9或V10的固件版本呢?
 楼主| 发表于 2020-4-17 15:04:23 | 显示全部楼层
可乐可乐 发表于 2020-4-17 14:41
谢谢,已安装成功。目前在学习STM32H7,能否发以下JLINK V9或V10 的下载链接?
驱动下载? JLINK使用方法? 还是JLINK购买地址?
 楼主| 发表于 2020-4-17 15:11:16 | 显示全部楼层
谢谢,已安装成功。目前在学习STM32H7,要使用JLINK V9 或V10.  按照教程对JLINK  V8固件进行升级,升级 ...
JLINK V8不行,不支持STM32H7。
发表于 2020-4-17 15:13:22 | 显示全部楼层
您的意思是不是需要我购买一个新的JLINK?版本是JLINK V9或V10?
 楼主| 发表于 2020-4-17 15:18:20 | 显示全部楼层
如果继续用JLINK的话,需要使用V9/V10
GMT+8, 2026-11-24 11:25 , Processed in 1.780876 second(s), 27 queries .
