查看: 1273|回复: 1
[emWin] emwin中LCDConf_Lin_Template文件中几句函数不是特别理解
发表于 2022-11-30 16:39:35 | 显示全部楼层 |阅读模式
									使用DMA2D重定向颜色的批量转换
#define DEFINE_DMA2D_COLORCONVERSION(PFIX, PIXELFORMAT)                                                        \
static void _Color2IndexBulk_##PFIX##_DMA2D(LCD_COLOR * pColor, void * pIndex, U32 NumItems, U8 SizeOfIndex) { \
  _DMA_Color2IndexBulk(pColor, pIndex, NumItems, SizeOfIndex, PIXELFORMAT);                                    \
static void _Index2ColorBulk_##PFIX##_DMA2D(void * pIndex, LCD_COLOR * pColor, U32 NumItems, U8 SizeOfIndex) { \
  _DMA_Index2ColorBulk(pColor, pIndex, NumItems, SizeOfIndex, PIXELFORMAT);                                    \
/* 函数声明 */
static void _DMA_Index2ColorBulk(void * pIndex, LCD_COLOR * pColor, U32 NumItems, U8 SizeOfIndex, U32 PixelFormat);
static void _DMA_Color2IndexBulk(LCD_COLOR * pColor, void * pIndex, U32 NumItems, U8 SizeOfIndex, U32 PixelFormat);
/* 颜色转换 */
DEFINE_DMA2D_COLORCONVERSION(M8888I, LTDC_Pixelformat_ARGB8888)
DEFINE_DMA2D_COLORCONVERSION(M888,   LTDC_Pixelformat_ARGB8888) /* Internal pixel format of emWin is 32 bit, because of that ARGB8888 */
DEFINE_DMA2D_COLORCONVERSION(M565,   LTDC_Pixelformat_RGB565)
DEFINE_DMA2D_COLORCONVERSION(M1555I, LTDC_Pixelformat_ARGB1555)
DEFINE_DMA2D_COLORCONVERSION(M4444I, LTDC_Pixelformat_ARGB4444)
发表于 2022-12-1 13:28:08 | 显示全部楼层
以DEFINE_DMA2D_COLORCONVERSION(M8888I, LTDC_Pixelformat_ARGB8888)为例,宏定义一次,实际对应的
static void _Color2IndexBulk_M8888I_DMA2D(LCD_COLOR * pColor, void * pIndex, U32 NumItems, U8 SizeOfIndex) { \
  _DMA_Color2IndexBulk(pColor, pIndex, NumItems, SizeOfIndex, LTDC_Pixelformat_ARGB8888);                                    \
static void _Index2ColorBulk_M8888I_DMA2D(void * pIndex, LCD_COLOR * pColor, U32 NumItems, U8 SizeOfIndex) { \
  _DMA_Index2ColorBulk(pIndex, pColor, NumItems, SizeOfIndex, LTDC_Pixelformat_ARGB8888);                                    \
GMT+8, 2026-11-23 23:48 , Processed in 0.357394 second(s), 24 queries .
