查看: 1993|回复: 0
[FreeRTOS] FreeRTOS的ListItem_t和MiniListItem_t区别
发表于 2022-11-8 12:29:50 | 显示全部楼层 |阅读模式
ListItem_t
struct xLIST_ITEM
	listFIRST_LIST_ITEM_INTEGRITY_CHECK_VALUE			/*< Set to a known value if configUSE_LIST_DATA_INTEGRITY_CHECK_BYTES is set to 1. */
	configLIST_VOLATILE TickType_t xItemValue;			/*< The value being listed.  In most cases this is used to sort the list in descending order. */
	struct xLIST_ITEM * configLIST_VOLATILE pxNext;		/*< Pointer to the next ListItem_t in the list. */
	struct xLIST_ITEM * configLIST_VOLATILE pxPrevious;	/*< Pointer to the previous ListItem_t in the list. */
	void * pvOwner;										/*< Pointer to the object (normally a TCB) that contains the list item.  There is therefore a two way link between the object containing the list item and the list item itself. */
	struct xLIST * configLIST_VOLATILE pxContainer;		/*< Pointer to the list in which this list item is placed (if any). */
	listSECOND_LIST_ITEM_INTEGRITY_CHECK_VALUE			/*< Set to a known value if configUSE_LIST_DATA_INTEGRITY_CHECK_BYTES is set to 1. */
typedef struct xLIST_ITEM ListItem_t;					/* For some reason lint wants this as two separate definitions. */
MiniListItem_t
struct xMINI_LIST_ITEM
typedef struct xMINI_LIST_ITEM MiniListItem_t;
GMT+8, 2026-11-24 15:16 , Processed in 0.745952 second(s), 24 queries .
