查看: 2184|回复: 0
ThreadX USBX升级至V6.2.0,更多协议开始支持裸机使用(2022-10-31)
发表于 2022-10-31 03:41:16 | 显示全部楼层 |阅读模式
论坛下载:
https://forum.anfulai.cn/forum.php?mod=viewthread&tid=97925
Github下载:
https://github.com/azure-rtos/usbx/releases
Improved standalone host HID keyboard OUTPUT report handling, files modified:
        ux_host_class_hid_keyboard.h
        ux_host_class_hid_keyboard_tasks_run.c
    Fixed/improved ethernet related classes (CDC-ECM and RNDIS), files modified:
        ux_api.h
        ux_user_sample.h
        ux_host_stack_transfer_request_abort.c
        ux_device_class_cdc_ecm.h
        ux_device_class_cdc_ecm_bulkin_thread.c
        ux_device_class_cdc_ecm_bulkout_thread.c
        ux_device_class_cdc_ecm_initialize.c
        ux_device_class_cdc_ecm_uninitialize.c
        ux_device_class_rndis.h
        ux_device_class_rndis_bulkin_thread.c
        ux_device_class_rndis_bulkout_thread.c
        ux_device_class_rndis_initialize.c
        ux_host_class_cdc_ecm.h
        ux_host_class_cdc_ecm_activate.c
        ux_host_class_cdc_ecm_deactivate.c
        ux_host_class_cdc_ecm_thread.c
        ux_host_class_cdc_ecm_transmission_callback.c
        ux_host_class_cdc_ecm_write.c
    Added device audio class (UAC) standalone support, files modified/added:
        ux_device_class_audio.h
        ux_device_class_audio_activate.c
        ux_device_class_audio_change.c
        ux_device_class_audio_feedback_thread_entry.c
        ux_device_class_audio_initialize.c
        ux_device_class_audio_interrupt_send.c
        ux_device_class_audio_read_thread_entry.c
        ux_device_class_audio_reception_start.c
        ux_device_class_audio_transmission_start.c
        ux_device_class_audio_write_thread_entry.c
        ux_device_class_audio_feedback_task_function.c
        ux_device_class_audio_interrupt_task_function.c
        ux_device_class_audio_read_task_function.c
        ux_device_class_audio_tasks_run.c
        ux_device_class_audio_write_task_function.c
    Added device video class (UVC) standalone support, files modified/added:
        ux_device_class_video.h
        ux_device_class_video_activate.c
        ux_device_class_video_change.c
        ux_device_class_video_initialize.c
        ux_device_class_video_read_thread_entry.c
        ux_device_class_video_reception_start.c
        ux_device_class_video_transmission_start.c
        ux_device_class_video_write_thread_entry.c
        ux_device_class_video_tasks_run.c
        ux_device_class_video_read_task_function.c
        ux_device_class_video_write_task_function.c
    Fixed/improved host ASIX support, files modified:
        ux_api.h
        ux_host_class_asix.h
        ux_host_class_asix_activate.c
        ux_host_class_asix_deactivate.c
        ux_host_class_asix_endpoints_get.c
        ux_host_class_asix_entry.c
        ux_host_class_asix_interrupt_notification.c
        ux_host_class_asix_reception_callback.c
        ux_host_class_asix_thread.c
        ux_host_class_asix_transmission_callback.c
        ux_host_class_asix_write.c
    Allowed user defined UX_ALIGN_MIN, the minimal byte align of memory allocation, files modified:
        ux_api.h
        ux_user_sample.h
    Improved host video (UVC) VC header check, file modified:
        ux_host_class_video_activate.c
    Added descriptor length check when scanning configuration to find CDC ECM MAC string index, file modified:
        ux_host_class_cdc_ecm_mac_address_get.c
    Fixed standalone hub port reset speed handling, file modified:
        ux_host_class_hub_tasks_run.c
    Fixed standalone hub port power on delay calculation, file modified:
        ux_host_class_hub_entry.c
    Fixed return code, files modified:
        ux_device_class_cdc_acm_read_run.c
        ux_device_class_cdc_acm_write_run.c
    Fixed standalone host no class interfaces activation issue, file modified:
        ux_host_stack_tasks_run.c
    Added compile option to control interface instance (currently owned physical endpoints) creation, files modified:
        ux_api.h
        ux_user_sample.h
        ux_host_stack_configuration_instance_create.c
        ux_host_stack_configuration_instance_delete.c
    Added media buffer size check before invoking media open, file modified:
        ux_host_class_storage_media_open.c
    Added standalone device printer support, files modified/added:
        ux_device_class_printer.h
        ux_device_class_printer_initialize.c
        ux_device_class_printer_soft_reset.c
        ux_device_class_printer_uninitialize.c
        ux_device_class_printer_read_run.c
        ux_device_class_printer_write_run.c
    Various files were modified to improve internal logic, comments and variable namings.
GMT+8, 2026-10-26 00:37 , Processed in 0.117013 second(s), 24 queries .
