查看: 2251|回复: 1
[CMSIS-RTOS] RTX5的信号量控制块没有做列表,就是独立的一个结构体变量,没法做遍历操作
发表于 2022-10-28 01:07:38 | 显示全部楼层 |阅读模式
信号量列表创建太简单了,没有做列表管理
/// Create and Initialize a Semaphore object.
/// \note API identical to osSemaphoreNew
static osSemaphoreId_t svcRtxSemaphoreNew (uint32_t max_count, uint32_t initial_count, const osSemaphoreAttr_t *attr) {
  os_semaphore_t *semaphore;
  uint8_t         flags;
  const char     *name;
  // Check parameters
  if ((max_count == 0U) || (max_count > osRtxSemaphoreTokenLimit) || (initial_count > max_count)) {
    EvrRtxSemaphoreError(NULL, (int32_t)osErrorParameter);
    //lint -e{904} "Return statement before end of function" [MISRA Note 1]
    return NULL;
  // Process attributes
  if (attr != NULL) {
    name      = attr->name;
    //lint -e{9079} "conversion from pointer to void to pointer to other type" [MISRA Note 6]
    semaphore = attr->cb_mem;
    if (semaphore != NULL) {
      //lint -e(923) -e(9078) "cast from pointer to unsigned int" [MISRA Note 7]
      if ((((uint32_t)semaphore & 3U) != 0U) || (attr->cb_size < sizeof(os_semaphore_t))) {
        EvrRtxSemaphoreError(NULL, osRtxErrorInvalidControlBlock);
        return NULL;
    } else {
      if (attr->cb_size != 0U) {
        return NULL;
  } else {
    name      = NULL;
    semaphore = NULL;
  // Allocate object memory if not provided
  if (semaphore == NULL) {
    if (osRtxInfo.mpi.semaphore != NULL) {
      //lint -e{9079} "conversion from pointer to void to pointer to other type" [MISRA Note 5]
      semaphore = osRtxMemoryPoolAlloc(osRtxInfo.mpi.semaphore);
    } else {
      semaphore = osRtxMemoryAlloc(osRtxInfo.mem.common, sizeof(os_semaphore_t), 1U);
#ifdef RTX_OBJ_MEM_USAGE
      uint32_t used;
      osRtxSemaphoreMemUsage.cnt_alloc++;
      used = osRtxSemaphoreMemUsage.cnt_alloc - osRtxSemaphoreMemUsage.cnt_free;
      if (osRtxSemaphoreMemUsage.max_used < used) {
        osRtxSemaphoreMemUsage.max_used = used;
#endif
    flags = osRtxFlagSystemObject;
  } else {
    flags = 0U;
    // Initialize control block
    semaphore->id          = osRtxIdSemaphore;
    semaphore->flags       = flags;
    semaphore->name        = name;
    semaphore->thread_list = NULL;
    semaphore->tokens      = (uint16_t)initial_count;
    semaphore->max_tokens  = (uint16_t)max_count;
    // Register post ISR processing function
    osRtxInfo.post_process.semaphore = osRtxSemaphorePostProcess;
    EvrRtxSemaphoreCreated(semaphore, semaphore->name);
  } else {
    EvrRtxSemaphoreError(NULL,(int32_t)osErrorNoMemory);
  return semaphore;
 楼主| 发表于 2022-10-30 01:42:04 | 显示全部楼层
如果全局动态创建方式,找到检索办法了,可以从全局动态内存里面动态检索。
GMT+8, 2026-11-25 21:48 , Processed in 0.214732 second(s), 24 queries .
