查看: 2248|回复: 1
[IAR] IAR链接器支持将剩余RAM分配给指定空间(比如栈、堆)
More we do, more we can do.
发表于 2022-10-11 13:40:16 | 显示全部楼层 |阅读模式
环境:IAR for ARM 8.0+  《The linker configuration file》章节
expanding size
The block will expand to use all available space in the memory range where it is placed.
示例:
/* Create a block with a minimum size for the heap that will use
all remaining space in its memory range */
define block HEAP with minimum size = 4K, expanding size,
alignment = 8 { };
发表于 2022-10-11 15:54:39 | 显示全部楼层
谢谢分享。
GMT+8, 2026-11-24 13:13 , Processed in 1.459694 second(s), 27 queries .
