查看: 1536|回复: 0
[ThreadX全家桶] ThreadX的信号量Trace功能,主要是跟踪变量_tx_semaphore_created_ptr
发表于 2022-10-9 16:46:53 | 显示全部楼层 |阅读模式
通过_tx_semaphore_created_ptr可以将所有信号量链接出来
/* Include necessary system files.  */
#include "tx_api.h"
#include "tx_semaphore.h"
#ifndef TX_INLINE_INITIALIZATION
/* Locate semaphore component data in this file.  */
/* Define the head pointer of the created semaphore list.  */
TX_SEMAPHORE *   _tx_semaphore_created_ptr;
/* Define the variable that holds the number of created semaphores. */
ULONG            _tx_semaphore_created_count;
#ifdef TX_SEMAPHORE_ENABLE_PERFORMANCE_INFO
/* Define the total number of semaphore puts.  */
ULONG            _tx_semaphore_performance_put_count;
/* Define the total number of semaphore gets.  */
ULONG            _tx_semaphore_performance_get_count;
/* Define the total number of semaphore suspensions.  */
ULONG            _tx_semaphore_performance_suspension_count;
/* Define the total number of semaphore timeouts.  */
ULONG            _tx_semaphore_performance_timeout_count;
#endif
GMT+8, 2026-11-23 23:49 , Processed in 0.865199 second(s), 24 queries .
