查看: 1392|回复: 0
[Lua] LUA做的RGB565转RGB555
发表于 2022-9-28 12:49:02 | 显示全部楼层 |阅读模式
这效率一般,得弄个更高效的。
[Lua] 纯文本查看 复制代码
function SwitchStr(stryy, len)
	local r
	local g
	local b
    local str44
    local str55
    local byte0
    local byte1
    local pixel
    local Color16
    str44=""
    for ii=1, len//2, 1 do
        byte0, byte1 = string.byte(stryy,  2*ii-1, 2*ii)
        pixel = byte1*256+byte0
        r = ((pixel & 0xF800) >> 8)
		g = ((pixel & 0x07E0) >> 3)
		b = ((pixel & 0x001F) << 3)
        --16 bpp Bitmaps in windows are 555: rrrrrgggggbbbbb
        r = ( r * 31 + 127) // 255
        g = ( g * 31 + 127) // 255
        b = ( b * 31 + 127) // 255
        Color16 = (r << 10) | (g << 5) | b
        byte1 = Color16//256
        byte0 = Color16%256
        str55 = string.format("%c%c", byte0, byte1)
        str44 = str44..str55
    end
    printf(string.len(str44))
	return str44
end
GMT+8, 2026-10-23 04:22 , Processed in 0.262388 second(s), 24 queries .
