查看: 1835|回复: 4
[技术讨论] STM32F446 PC0 I/0口翻转问题
发表于 2022-9-21 14:03:51 | 显示全部楼层 |阅读模式
程序很简单就是控制下PC0 进行翻转,使用STM32CubeMX生产程序,程序如下现在的问题是当控制PC0进行翻转时I/O口根本就不动,当改为控制PC13时PC0进行翻转,那问题来了,我要控制PC13翻转时又控制什么I/O口进行动作
void MX_GPIO_Init(void)
  GPIO_InitTypeDef GPIO_InitStruct = {0};
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOE_CLK_ENABLE();
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOH_CLK_ENABLE();
  __HAL_RCC_GPIOD_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(GPIOE, GPIO_PIN_3, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(GPIOC, GPIO_PIN_13|GPIO_PIN_0|GPIO_PIN_3, GPIO_PIN_RESET);
  /*Configure GPIO pin : PE3 */
  GPIO_InitStruct.Pin = GPIO_PIN_3;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
  HAL_GPIO_Init(GPIOE, &GPIO_InitStruct);
  /*Configure GPIO pins : PC13 PC0 PC3 */
  GPIO_InitStruct.Pin = GPIO_PIN_13|GPIO_PIN_0|GPIO_PIN_3;
  HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
while(1)
 楼主| 发表于 2022-9-21 14:05:20 | 显示全部楼层
while(1)
          HAL_GPIO_WritePin(GPIOC, GPIO_PIN_0, GPIO_PIN_RESET);
          delay_ms(50000);
          HAL_GPIO_WritePin(GPIOC, GPIO_PIN_0, GPIO_PIN_SET);
          delay_ms(50000);
补下PC0翻转的程序
发表于 2022-9-21 15:11:33 | 显示全部楼层
xad74 发表于 2022-9-21 14:05
while(1)
看着没什么问题, delay_ms(50000);改成HAL_Delay
 楼主| 发表于 2022-9-21 15:54:12 | 显示全部楼层
仿真时ODR0变化,PC0口不变,ODR13变化,PC0口变化,446是有管家隐射类的寄存器吗
发表于 2022-9-21 16:04:53 | 显示全部楼层
IO模式是上电默认状态,问题比较简单,尝试自己解决下。
GMT+8, 2026-11-28 17:41 , Processed in 1.317794 second(s), 24 queries .
