查看: 2084|回复: 2
[RT1020] 硬件I2c无法工作
发表于 2022-8-5 16:49:03 | 显示全部楼层 |阅读模式
void BspI2cInit(void)
    uint32_t i2cclk=0;
    lpi2c_master_config_t  tMasterConfig;
    CLOCK_SetMux(kCLOCK_Lpi2cMux,0);   //LPI2C时钟源为PLL3=60Mhz
    CLOCK_SetDiv(kCLOCK_Lpi2cDiv,5);   //分频设置,分频值为5+1,所以LPI2C CLK=10Mhz
    //配置IO作为I2C
    IOMUXC_SetPinMux(IOMUXC_GPIO_AD_B1_08_LPI2C2_SCL,1);
    IOMUXC_SetPinMux(IOMUXC_GPIO_AD_B1_09_LPI2C2_SDA,1);
    //配置I2C引脚功能,
    //低转换速度,驱动能力为R0/6,速度为100Mhz,开路输出,使能pull/keepr
        //选择keeper功能,上拉22K Ohm,关闭Hyst
    IOMUXC_SetPinConfig(IOMUXC_GPIO_AD_B1_08_LPI2C2_SCL, 0xD8B0);
    IOMUXC_SetPinConfig(IOMUXC_GPIO_AD_B1_09_LPI2C2_SDA, 0xD8B0);
    i2cclk=((CLOCK_GetFreq(kCLOCK_Usb1PllClk)/8)/(5+1));
    LPI2C_MasterGetDefaultConfig(&tMasterConfig);
    tMasterConfig.baudRate_Hz = 100000;
    LPI2C_MasterInit(LPI2C2, &tMasterConfig, i2cclk);
    uint8_t  ucTouchDat[8];
    lpi2c_master_transfer_t  tMasterXfer = {0};
    tMasterXfer.slaveAddress   = (0x20 >> 1);
    tMasterXfer.direction      = kLPI2C_Read;
    tMasterXfer.subaddress     = 0;
    tMasterXfer.subaddressSize = 0;
    tMasterXfer.data           = ucTouchDat;
    tMasterXfer.dataSize       = 8;
    tMasterXfer.flags          = kLPI2C_TransferDefaultFlag;
    while (1)
        LPI2C_MasterTransferBlocking(LPI2C2, &tMasterXfer);
配置如上, 时钟引脚一直未能测到时钟, 感觉NXP的硬件I2C好难用啊.
发表于 2022-8-5 16:59:03 | 显示全部楼层
 楼主| 发表于 2022-8-9 14:00:00 | 显示全部楼层
问题解决了, Pin要配置为Input才行, 默认是InputOutput, 无法工作.
GMT+8, 2026-11-23 05:24 , Processed in 0.547827 second(s), 22 queries .
