查看: 2525|回复: 2
ThreadX USBX升级支持V6.1.12(2022-08-02)
发表于 2022-8-2 14:44:05 | 显示全部楼层 |阅读模式
论坛下载:
https://forum.anfulai.cn/forum.php?mod=viewthread&tid=97925
更新记录:
 Fixed Pictbridge and PIMA issues, files modified:
        ux_pictbridge.h
        ux_pictbridge_dpsclient_object_info_get.c
        ux_pictbridge_dpsclient_object_info_send.c
        ux_pictbridge_dpshost_object_get.c
        ux_pictbridge_dpshost_response_get.c
        ux_pictbridge_dpshost_start.c
        ux_device_class_pima_interrupt_thread.c
        ux_device_class_pima_storage_info_get.c
        ux_host_class_pima.h
        ux_host_class_pima_device_info_get.c
        ux_host_class_pima_object_handles_get.c
        ux_host_class_pima_read.c
        ux_host_class_pima_storage_ids_get.c
    Improved host CDC-ECM MAC string validation, file modified:
        ux_host_class_cdc_ecm_mac_address_get.c
    Added standalone host/device HID interrupt OUT support, files modified:
        ux_host_class_hid_report_set_run.c
        ux_device_class_hid.h
        ux_device_class_hid_activate.c
        ux_device_class_hid_initialize.c
        ux_device_class_hid_read.c
        ux_device_class_hid_receiver_event_get.c
        ux_device_class_hid_receiver_initialize.c
        ux_device_class_hid_read_run.c
        ux_device_class_hid_receiver_tasks_run.c
    Updated dCSWDataResidue while handling device storage inquiry command, file modified:
        ux_device_class_storage_inquiry.c
    Added USB audio class (UAC) multiple sampling frequencies support, files modified:
        ux_device_class_audio20.h
        ux_device_class_audio20_control_process.c
        ux_device_class_audio10.h
        ux_device_class_audio10_control_process.c
    Added device audio class (UAC) optional interrupt support, files modified/added:
        ux_user_sample.h
        ux_class_audio10.h
        ux_class_audio20.h
        ux_device_class_audio.h
        ux_device_class_audio_activate.c
        ux_device_class_audio_initialize.c
        ux_device_class_audio_unitialize.c
        ux_device_class_audio_interrupt_send.c
        ux_device_class_audio_interrupt_thread_entry.c
    Added host audio class (UAC) optional interrupt endpoint support, files modified/added:
        ux_user_sample.h
        ux_host_class_audio.h
        ux_host_class_audio_activate.c
        ux_host_class_audio_deactivate.c
        ux_host_class_audio_device_type_get.c
        ux_host_class_audio_interrupt_notification.c
        ux_host_class_audio_interrupt_start.c
    In device DFU, validated request type for DNLOAD request in all states,
     and checked length for UPLOAD request in _UPLOAD_IDLE state, file modified:
        ux_device_class_dfu_control_request.c
    Added device CDC ACM and printer write auto ZLP option, files modified:
        ux_user_sample.h
        ux_device_class_cdc_acm.h
        ux_device_class_printer.h
        ux_device_class_cdc_acm_bulkin_thread.c
        ux_device_class_cdc_acm_write.c
        ux_device_class_cdc_acm_write_run.c
        ux_device_class_printer_write.c
    Fixed addressing issues in host controller driver, files modified:
        ux_hcd_ohci_asynchronous_endpoint_create.c
        ux_hcd_ohci_done_queue_process.c
    Added standalone host hub support, files modified/added:
        ux_host_stack.h
        ux_host_stack_device_resources_free.c
        ux_host_stack_new_device_get.c
        ux_host_stack_tasks_run.c
        ux_host_class_hub.h
        ux_host_class_hub_activate.c
        ux_host_class_hub_change_detect.c
        ux_host_class_hub_deactivate.c
        ux_host_class_hub_descriptor_get.c
        ux_host_class_hub_entry.c
        ux_host_class_hub_feature.c
        ux_host_class_hub_interrupt_endpoint_start.c
        ux_host_class_hub_port_change_connection_process.c
        ux_host_class_hub_status_get.c
        ux_host_class_hub_transfer_request_completed.c
        ux_host_class_hub_tasks_run.c
    Added definitions for device audio 2.0 clock multiplier support, file modified:
    Added host audio feedback and 2.0 protocol support, files modified/added:
        ux_host_class_audio_alternate_setting_locate.c
        ux_host_class_audio_control_get.c
        ux_host_class_audio_control_value_get.c
        ux_host_class_audio_control_value_set.c
        ux_host_class_audio_descriptor_get.c
        ux_host_class_audio_device_controls_list_get.c
        ux_host_class_audio_endpoints_get.c
        ux_host_class_audio_entry.c
        ux_host_class_audio_read.c
        ux_host_class_audio_streaming_sampling_get.c
        ux_host_class_audio_streaming_sampling_set.c
        ux_host_class_audio_transfer_request.c
        ux_host_class_audio_write.c
        ux_class_audio10.h
        ux_class_audio20.h
        ux_host_class_audio_control_request.c
        ux_host_class_audio_descriptors_parse.c
        ux_host_class_audio_entity_control_get.c
        ux_host_class_audio_entity_control_value_get.c
        ux_host_class_audio_entity_control_value_set.c
        ux_host_class_audio_feedback_get.c
        ux_host_class_audio_feedback_set.c
        ux_host_class_audio_feedback_transfer_completed.c
        ux_host_class_audio_raw_sampling_parse.c
        ux_host_class_audio_stop.c
    Improved UVC transfer abort/restart, files modified:
        ux_host_stack_endpoint_instance_create.c
        ux_host_class_video_ioctl.c
        ux_host_class_video_transfer_buffer_add.c
        ux_host_class_video_transfer_buffers_add.c
        ux_host_class_video_transfer_request.c
        ux_host_class_video_transfer_request_callback.c
        ux_hcd_ehci_hsisochronous_tds_process.c
        ux_hcd_ehci_request_isochronous_transfer.c
        ux_hcd_ehci_transfer_abort.c
    Fixed ipv6 support issues, files modified:
        ux_network_driver.c
        ux_network_driver.h
    Fixed OHCI PRSC (Port Reset) issue, files modified:
        ux_hcd_ohci_initialize.c
        ux_hcd_ohci_interrupt_handler.c
        ux_hcd_ohci_port_reset.c
        ux_hcd_ohci.h
        ux_utility.h
    Various files were modified to improve internal logic, comments and variable namings.
发表于 2023-1-3 16:50:16 | 显示全部楼层
升级到6.1.12后模拟U盘进入HardFault_Handler中断了。
发表于 2023-1-3 18:09:28 | 显示全部楼层
是STM32CubeMX配置的问题,可以用6.1.12了
GMT+8, 2026-10-26 03:12 , Processed in 0.378148 second(s), 24 queries .
