查看: 2245|回复: 3
[其它] 发现一个宝库
发表于 2022-7-2 20:29:40 | 显示全部楼层 |阅读模式
这个文件夹下,居然有很多文件,现成的,稍微改一下就可以显示中文汉字了,还有很多实用的工具,库文件,太爽了
C:\Users\xxx\STM32Cube\Repository\STM32Cube_FW_H7_V1.9.1\Utilities\lcd
1. How To use this driver:
   - This driver is a generic driver that provides basic display services. It should
     be used by any platform once LCD is initialized and following draw methods are
         BSP_LCD_DrawBitmap
         BSP_LCD_DrawHLine
         BSP_LCD_DrawVLine
         BSP_LCD_FillRect
         BSP_LCD_ReadPixel
         BSP_LCD_WritePixel
         BSP_LCD_GetXSize
         BSP_LCD_GetYSize
         BSP_LCD_SetActiveLayer
   - At application level, once the LCD is initialized, user should call UTIL_LCD_SetFuncDriver()
     API to link board LCD drivers to BASIC GUI LCD drivers.
     User can then call the BASIC GUI services:
         UTIL_LCD_SetLayer()
         UTIL_LCD_SetDevice()
         UTIL_LCD_SetTextColor()
         UTIL_LCD_GetTextColor()
         UTIL_LCD_SetBackColor()
         UTIL_LCD_GetBackColor()
         UTIL_LCD_SetFont()
         UTIL_LCD_GetFont()
         UTIL_LCD_Clear)
         UTIL_LCD_ClearStringLine()
         UTIL_LCD_DisplayStringAtLine()
         UTIL_LCD_DisplayStringAt()
         UTIL_LCD_DisplayChar()
         UTIL_LCD_GetPixel()
         UTIL_LCD_SetPixel()
         UTIL_LCD_FillRGBRect()
         UTIL_LCD_DrawHLine()
         UTIL_LCD_DrawVLine()
         UTIL_LCD_DrawBitmap()
         UTIL_LCD_FillRect()
         UTIL_LCD_DrawLine()
         UTIL_LCD_DrawRect()
         UTIL_LCD_DrawCircle()
发表于 2022-7-3 00:37:58 | 显示全部楼层
谢谢,这个我之前也分享过,论坛有个坛友还专门移植玩了下。
分享BASIC GUI
https://forum.anfulai.cn/forum.p ... 2235&fromuid=58
 楼主| 发表于 2022-7-3 08:16:46 | 显示全部楼层
可能我之前找的就是这个,只不过想不起什么名字,所以搜不到,basic gui
发表于 2022-7-4 00:30:07 | 显示全部楼层
之前发的那个帖子,我也想不起来关键词了,仅想起了坛友发的这个。
GMT+8, 2026-11-23 22:50 , Processed in 1.103828 second(s), 27 queries .
