查看: 3421|回复: 7
[有问必答] STM32F405使用UART DMA空闲中断接受不定长数据头包数据乱码问题
发表于 2022-6-29 16:44:57 | 显示全部楼层 |阅读模式
代码如下
static void MX_USART1_UART_Init(void)
  /* USER CODE BEGIN USART1_Init 0 */
  /* USER CODE END USART1_Init 0 */
  /* USER CODE BEGIN USART1_Init 1 */
  /* USER CODE END USART1_Init 1 */
  huart1.Instance = USART1;
  huart1.Init.BaudRate = 115200;
  huart1.Init.WordLength = UART_WORDLENGTH_8B;
  huart1.Init.StopBits = UART_STOPBITS_1;
  huart1.Init.Parity = UART_PARITY_NONE;
  huart1.Init.Mode = UART_MODE_TX_RX;
  huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart1.Init.OverSampling = UART_OVERSAMPLING_16;
  if (HAL_UART_Init(&huart1) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN USART1_Init 2 */
  /* USER CODE END USART1_Init 2 */
void HAL_UART_MspInit(UART_HandleTypeDef* huart)
  GPIO_InitTypeDef GPIO_InitStruct = {0};
  if(huart->Instance==USART1)
  /* USER CODE BEGIN USART1_MspInit 0 */
  /* USER CODE END USART1_MspInit 0 */
    /* Peripheral clock enable */
    __HAL_RCC_USART1_CLK_ENABLE();
    __HAL_RCC_GPIOA_CLK_ENABLE();
    /**USART1 GPIO Configuration
    PA9     ------> USART1_TX
    PA10     ------> USART1_RX
    GPIO_InitStruct.Pin = GPIO_PIN_9|GPIO_PIN_10;
    GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
    GPIO_InitStruct.Pull = GPIO_PULLUP;
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
    GPIO_InitStruct.Alternate = GPIO_AF7_USART1;
    HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
    /* USART1 DMA Init */
    /* USART1_RX Init */
    hdma_usart1_rx.Instance = DMA2_Stream2;
    hdma_usart1_rx.Init.Channel = DMA_CHANNEL_4;
    hdma_usart1_rx.Init.Direction = DMA_PERIPH_TO_MEMORY;
    hdma_usart1_rx.Init.PeriphInc = DMA_PINC_DISABLE;
    hdma_usart1_rx.Init.MemInc = DMA_MINC_ENABLE;
    hdma_usart1_rx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
    hdma_usart1_rx.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE;
    hdma_usart1_rx.Init.Mode = DMA_NORMAL;
    hdma_usart1_rx.Init.Priority = DMA_PRIORITY_LOW;
    hdma_usart1_rx.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
    if (HAL_DMA_Init(&hdma_usart1_rx) != HAL_OK)
      Error_Handler();
    __HAL_LINKDMA(huart,hdmarx,hdma_usart1_rx);
    /* USART1 interrupt Init */
    HAL_NVIC_SetPriority(USART1_IRQn, 0, 0);
    HAL_NVIC_EnableIRQ(USART1_IRQn);
  /* USER CODE BEGIN USART1_MspInit 1 */
    HAL_NVIC_SetPriority(DMA2_Stream2_IRQn, 5, 0);
   HAL_NVIC_EnableIRQ(DMA2_Stream2_IRQn);
                __HAL_UART_ENABLE_IT(&huart1, UART_IT_IDLE);
                HAL_UART_Receive_DMA(&huart1,rxbuffer,1);    //接收下一次DMA
  /* USER CODE END USART1_MspInit 1 */
void USART1_IRQHandler(void)
  /* USER CODE BEGIN USART1_IRQn 0 */
  /* USER CODE END USART1_IRQn 0 */
  HAL_UART_IRQHandler(&huart1);
  /* USER CODE BEGIN USART1_IRQn 1 */
        uint32_t temp;
  if((__HAL_UART_GET_FLAG(&huart1,UART_FLAG_IDLE) != RESET) )
     __HAL_UART_CLEAR_IDLEFLAG(&huart1);
                HAL_UART_DMAStop(&huart1);
                // 获取DMA当前还有多少未填充 判断接收数据帧长度
    uart1_rx_len = 4096 -__HAL_DMA_GET_COUNTER(&hdma_usart1_rx);//((DMA_Stream_TypeDef *)huart1.hdmarx->Instance)->NDTR;//// (hdma_usart1_rx.Instance->CNDTR);//
                uart1_recv_flag = 1;           //接受标志
                HAL_UART_Receive_DMA(&huart1,rxbuffer,4096);    //接收下一次DMA
    HAL_UART_Transmit(&huart1, (uint8_t *)&rxbuffer, uart1_rx_len, 0xffff);
  /* USER CODE END USART1_IRQn 1 */
为什么重启后第一次接收中断产生长度是4096的乱码数据,之后都能正常,哪里导致__HAL_DMA_GET_COUNTER(&hdma_usart1_rx);获取长度无效
发表于 2022-6-30 00:01:33 | 显示全部楼层
都用空闲了怎么不把循环接收DMA_CIRCULAR Mode打开,不是更香么?
翻了下以前写的代码主要相关的是下面两,我发过H7的程序。
void HAL_UARTEx_RxEventCallback(UART_HandleTypeDef *huart, uint16_t Size)
HAL_UARTEx_ReceiveToIdle_DMA(&huart1, s_rx_buf1, UART1_RX_BUF_SIZE); /* 启动DMA */
发表于 2022-6-30 01:31:31 | 显示全部楼层
你的DMA时钟配置在哪里。务必要在DMA之前优先配置。
 楼主| 发表于 2022-6-30 08:57:05 | 显示全部楼层
DMA时钟放在了UART初始化最前面也一样现象,我用标准库没问题,但是用HAL库就这样
 楼主| 发表于 2022-6-30 09:03:24 | 显示全部楼层
翻了下以前写的代码主要相关的是下面两 ...
这样也没啥用
发表于 2022-6-30 09:46:18 | 显示全部楼层
不行直接参考我们论坛分享的得了。
基于V6的CMSIS-Driver串口应用,支持8串口DMA不定长收发,比CubeMX还要省事
https://forum.anfulai.cn/forum.php?mod=viewthread&tid=93714
STM32V6之串口HAL库串口空闲中断接收不定长字节代码实现
https://forum.anfulai.cn/forum.php?mod=viewthread&tid=101377
发表于 2022-6-30 12:44:09 | 显示全部楼层
    uint32_t remainBytes_InDmaRx = 0;
    if ((__HAL_UART_GET_FLAG(&huart6, UART_FLAG_IDLE) != RESET))
        __HAL_UART_CLEAR_IDLEFLAG(&huart6);
        /* Get remain bytes in DMA rx counts. */
        remainBytes_InDmaRx = __HAL_DMA_GET_COUNTER(huart6.hdmarx);
        HAL_UART_AbortReceive(&huart6);
        RxRing_Write(&dmaRxBuffer[0], (RECV_BUFF_SIZE - remainBytes_InDmaRx));
        HAL_UART_Receive_DMA(&huart6, dmaRxBuffer, RECV_BUFF_SIZE);
    HAL_UART_IRQHandler(&huart6);
 楼主| 发表于 2022-7-22 13:53:12 | 显示全部楼层
找到了解决第一笔数据无法收发问题方法,就是  __HAL_UART_ENABLE_IT(&huart1, UART_IT_IDLE);必须前面加延时放在串口初始化后面才行。代码如下
    Error_Handler();
        HAL_Delay(100);
        HAL_UART_Receive_DMA(&huart1, rxbuffer, 100);
GMT+8, 2026-11-28 17:41 , Processed in 1.081997 second(s), 27 queries .
