查看: 2222|回复: 3
YModem源码开头这几句代码作用是啥
发表于 2022-6-20 13:53:50 | 显示全部楼层 |阅读模式
请教大家,YModem源码开头这几句代码作用是啥?好像我iap还没操作过stm32读写保护啊?
/* Get the number of block (4 or 2 pages) from where the user program will be loaded */
  BlockNbr = (FlashDestination - 0x08000000) >> 12;
  /* Compute the mask to test if the Flash memory, where the user program will be
     loaded, is write protected */
#if defined (STM32F10X_MD) || defined (STM32F10X_MD_VL)
  UserMemoryMask = ((uint32_t)~((1 << BlockNbr) - 1));
#else /* USE_STM3210E_EVAL */
  if (BlockNbr < 62)
    UserMemoryMask = ((uint32_t)0x80000000);
#endif /* (STM32F10X_MD) || (STM32F10X_MD_VL) */
  /* Test if any page of Flash memory where program user will be loaded is write protected */
  if ((FLASH_GetWriteProtectionOptionByte() & UserMemoryMask) != UserMemoryMask)
    FlashProtection = 1;
    FlashProtection = 0;
发表于 2022-6-21 01:35:51 | 显示全部楼层
看注释应该就是通过选项字节判断扇区读写保护。
 楼主| 发表于 2022-6-21 10:29:33 | 显示全部楼层
之前我没加过写保护,应该去掉这些判断也行吧?
发表于 2022-6-21 10:44:35 | 显示全部楼层
用不到,直接删掉即可
GMT+8, 2026-11-25 11:31 , Processed in 0.215366 second(s), 24 queries .
