查看: 4093|回复: 3
[HAL] 注意函数HAL_RCC_DeInit,这个里面隐藏了个SysTick再次初始化
发表于 2022-6-9 13:37:11 | 显示全部楼层 |阅读模式
HAL_RCC_DeInit
大家调用这个函数要特别注意:
  * @brief  Resets the RCC clock configuration to the default reset state.
  * @note   The default reset state of the clock configuration is given below:
  *            - HSI ON and used as system clock source
  *            - HSE, PLL1, PLL2 and PLL3 OFF
  *            - AHB, APB Bus pre-scaler set to 1.
  *            - CSS, MCO1 and MCO2 OFF
  *            - All interrupts disabled
  * @note   This function doesn't modify the configuration of the
  *            - Peripheral clocks
  *            - LSI, LSE and RTC clocks
  * @retval HAL status
HAL_StatusTypeDef HAL_RCC_DeInit(void)
  uint32_t tickstart;
        /* Increasing the CPU frequency */
  if(FLASH_LATENCY_DEFAULT  > __HAL_FLASH_GET_LATENCY())
    /* Program the new number of wait states to the LATENCY bits in the FLASH_ACR register */
    __HAL_FLASH_SET_LATENCY(FLASH_LATENCY_DEFAULT);
    /* Check that the new number of wait states is taken into account to access the Flash
    memory by reading the FLASH_ACR register */
    if(__HAL_FLASH_GET_LATENCY() != FLASH_LATENCY_DEFAULT)
      return HAL_ERROR;
  /* Get Start Tick */
  tickstart = HAL_GetTick();
  /* Set HSION bit */
  SET_BIT(RCC->CR, RCC_CR_HSION);
  /* Wait till HSI is ready */
  while (READ_BIT(RCC->CR, RCC_CR_HSIRDY) == 0U)
    if ((HAL_GetTick() - tickstart) > HSI_TIMEOUT_VALUE)
      return HAL_TIMEOUT;
  /* Set HSITRIM[6:0] bits to the reset value */
  SET_BIT(RCC->HSICFGR, RCC_HSICFGR_HSITRIM_6);
  /* Reset CFGR register */
  CLEAR_REG(RCC->CFGR);
  /* Update the SystemCoreClock and SystemD2Clock global variables */
  SystemCoreClock = HSI_VALUE;
  SystemD2Clock = HSI_VALUE;
  /* Adapt Systick interrupt period */
  if(HAL_InitTick(uwTickPrio) != HAL_OK)
    return HAL_ERROR;
  /* Wait till clock switch is ready */
  while (READ_BIT(RCC->CFGR, RCC_CFGR_SWS) != 0U)
    if ((HAL_GetTick() - tickstart) > CLOCKSWITCH_TIMEOUT_VALUE)
      return HAL_TIMEOUT;
  /* Reset CSION, CSIKERON, HSEON, HSI48ON, HSECSSON, HSIDIV bits */
  CLEAR_BIT(RCC->CR, RCC_CR_HSEON | RCC_CR_HSIKERON| RCC_CR_HSIDIV| RCC_CR_HSIDIVF| RCC_CR_CSION | RCC_CR_CSIKERON  \
  | RCC_CR_HSI48ON | RCC_CR_CSSHSEON);
  /* Wait till HSE is disabled */
  while (READ_BIT(RCC->CR, RCC_CR_HSERDY) != 0U)
    if ((HAL_GetTick() - tickstart) > HSE_TIMEOUT_VALUE)
      return HAL_TIMEOUT;
  /* Clear PLLON bit */
  CLEAR_BIT(RCC->CR, RCC_CR_PLL1ON);
  /* Wait till PLL is disabled */
  while (READ_BIT(RCC->CR, RCC_CR_PLL1RDY) != 0U)
    if ((HAL_GetTick() - tickstart) > PLL_TIMEOUT_VALUE)
      return HAL_TIMEOUT;
  /* Reset PLL2ON bit */
  CLEAR_BIT(RCC->CR, RCC_CR_PLL2ON);
  /* Wait till PLL2 is disabled */
  while (READ_BIT(RCC->CR, RCC_CR_PLL2RDY) != 0U)
      return HAL_TIMEOUT;
  /* Reset PLL3 bit */
  CLEAR_BIT(RCC->CR, RCC_CR_PLL3ON);
  /* Wait till PLL3 is disabled */
  while (READ_BIT(RCC->CR, RCC_CR_PLL3RDY) != 0U)
      return HAL_TIMEOUT;
#if defined(RCC_D1CFGR_HPRE)
  /* Reset D1CFGR register */
  CLEAR_REG(RCC->D1CFGR);
  /* Reset D2CFGR register */
  CLEAR_REG(RCC->D2CFGR);
  /* Reset D3CFGR register */
  CLEAR_REG(RCC->D3CFGR);
#else
  /* Reset CDCFGR1 register */
  CLEAR_REG(RCC->CDCFGR1);
  /* Reset CDCFGR2 register */
  CLEAR_REG(RCC->CDCFGR2);
  /* Reset SRDCFGR register */
  CLEAR_REG(RCC->SRDCFGR);
#endif
  /* Reset PLLCKSELR register to default value */
  RCC->PLLCKSELR= RCC_PLLCKSELR_DIVM1_5|RCC_PLLCKSELR_DIVM2_5|RCC_PLLCKSELR_DIVM3_5;
  /* Reset PLLCFGR register to default value */
  WRITE_REG(RCC->PLLCFGR, 0x01FF0000U);
  /* Reset PLL1DIVR register to default value */
  WRITE_REG(RCC->PLL1DIVR,0x01010280U);
  /* Reset PLL1FRACR register */
  CLEAR_REG(RCC->PLL1FRACR);
  /* Reset PLL2DIVR register to default value */
  WRITE_REG(RCC->PLL2DIVR,0x01010280U);
  /* Reset PLL2FRACR register */
  CLEAR_REG(RCC->PLL2FRACR);
  /* Reset PLL3DIVR register to default value */
  WRITE_REG(RCC->PLL3DIVR,0x01010280U);
  /* Reset PLL3FRACR register */
  CLEAR_REG(RCC->PLL3FRACR);
  /* Reset HSEBYP bit */
  CLEAR_BIT(RCC->CR, RCC_CR_HSEBYP);
  /* Disable all interrupts */
  CLEAR_REG(RCC->CIER);
  /* Clear all interrupts flags */
  WRITE_REG(RCC->CICR,0xFFFFFFFFU);
  /* Reset all RSR flags */
  SET_BIT(RCC->RSR, RCC_RSR_RMVF);
      /* Decreasing the number of wait states because of lower CPU frequency */
  if(FLASH_LATENCY_DEFAULT  < __HAL_FLASH_GET_LATENCY())
      return HAL_ERROR;
  return HAL_OK;
参与人数 1金币 +20 收起 理由
逛街在这里 + 20 赞一个!
发表于 2022-9-30 00:38:06 | 显示全部楼层
这个再次初始化会带来什么后果吗?
 楼主| 发表于 2022-10-1 00:33:48 | 显示全部楼层
weboser 发表于 2022-9-30 00:38
这个再次初始化会带来什么后果吗?
比如此贴4楼的问题
https://forum.anfulai.cn/forum.php?mod=viewthread&tid=115762
发表于 2024-3-21 21:00:54 | 显示全部楼层
好家伙,就这个问题找了两天
GMT+8, 2026-10-25 07:44 , Processed in 0.161627 second(s), 25 queries .
