查看: 2068|回复: 1
如何知道当前DMA的传输位置
发表于 2022-5-14 16:04:12 | 显示全部楼层 |阅读模式
如何知道当前DMA的传输位置
发表于 2022-5-14 16:23:42 | 显示全部楼层
2040这个寄存器是可读可写的,读取出来的就是剩余传输次数。
/*! \brief  Set the number of bus transfers the channel will do
 *  \ingroup hardware_dma
 * \param channel DMA channel
 * \param trans_count The number of transfers (not NOT bytes, see channel_config_set_transfer_data_size)
 * \param trigger True to start the transfer immediately
static inline void dma_channel_set_trans_count(uint channel, uint32_t trans_count, bool trigger) {
    if (!trigger) {
        dma_channel_hw_addr(channel)->transfer_count = trans_count;
    } else {
        dma_channel_hw_addr(channel)->al1_transfer_count_trig = trans_count;
GMT+8, 2026-11-22 13:29 , Processed in 0.215318 second(s), 27 queries .
