查看: 1538|回复: 2
[ThreadX全家桶] ThreadX动态APP默认的MPU分配
发表于 2022-5-13 00:51:00 | 显示全部楼层 |阅读模式
这些知识还是得看源码才行:
/*  DESCRIPTION                                                           */
/*    This function sets up the MPU register definitions based on the     */
/*    module's memory characteristics.                                    */
/*    Default MPU layout:                                                 */
/*    Entry     Description                                               */
/*      0       Kernel mode entry                                         */
/*      1       Module code region                                        */
/*      2       Module code region                                        */
/*      3       Module code region                                        */
/*      4       Module code region                                        */
/*      5       Module data region                                        */
/*      6       Module data region                                        */
/*      7       Module data region                                        */
/*    If TXM_MODULE_MANAGER_16_MPU is defined, there are 16 MPU slots.    */
/*    MPU layout for the Cortex-M7:                                       */
/*      8       Module data region                                        */
/*      9       Module shared memory region                               */
/*      10      Module shared memory region                               */
/*      11      Module shared memory region                               */
/*      12      Unused region                                             */
/*      13      Unused region                                             */
/*      14      Unused region                                             */
/*      15      Unused region                                             */
 楼主| 发表于 2022-5-13 00:52:41 | 显示全部楼层
它这个配置不太方便用户添加自己的配置。
发表于 2022-5-13 08:54:36 | 显示全部楼层
硬汉大哥带领大家研究,大家玩起来都很有信心!
GMT+8, 2026-11-23 22:50 , Processed in 0.284253 second(s), 24 queries .
