查看: 2310|回复: 1
[SAI/I2S] STM32H7 HAL库,I2S 采样频率的设置问疑问。
发表于 2022-4-27 09:15:10 | 显示全部楼层 |阅读模式
我用这个SystemClock_Config() 设置不同的主频后,然后 I2Sxext_Mode_Config() 设置采样频率。是否设置不同的主频时,只要给 I2Sxext_Mode_Config() 的参数_usAudioFreq不变,实际设置的采样频率的就不变?
void SystemClock_Config(void)
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = {0};
  /** Supply configuration update enable
  HAL_PWREx_ConfigSupply(PWR_LDO_SUPPLY);
  /** Configure the main internal regulator output voltage
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE0);
  while(!__HAL_PWR_GET_FLAG(PWR_FLAG_VOSRDY)) {}
  /** Macro to configure the PLL clock source
  __HAL_RCC_PLL_PLLSOURCE_CONFIG(RCC_PLLSOURCE_HSE);
  /** Initializes the RCC Oscillators according to the specified parameters
  * in the RCC_OscInitTypeDef structure.
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLM = 5;
  RCC_OscInitStruct.PLL.PLLN = 40;        //112  80   ********不同的主频***********
  RCC_OscInitStruct.PLL.PLLP = 2;
  RCC_OscInitStruct.PLL.PLLQ = 2;
  RCC_OscInitStruct.PLL.PLLR = 2;
  RCC_OscInitStruct.PLL.PLLRGE = RCC_PLL1VCIRANGE_2;
  RCC_OscInitStruct.PLL.PLLVCOSEL = RCC_PLL1VCOWIDE;
  RCC_OscInitStruct.PLL.PLLFRACN = 0;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  /** Initializes the CPU, AHB and APB buses clocks
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2
                              |RCC_CLOCKTYPE_D3PCLK1|RCC_CLOCKTYPE_D1PCLK1;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.SYSCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_HCLK_DIV1;
  RCC_ClkInitStruct.APB3CLKDivider = RCC_APB3_DIV2;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_APB1_DIV2;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_APB2_DIV2;
  RCC_ClkInitStruct.APB4CLKDivider = RCC_APB4_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_7) != HAL_OK)
    Error_Handler();
void I2Sxext_Mode_Config(const uint16_t _usStandard, const uint16_t _usWordLen,const uint32_t _usAudioFreq)
        /* PLL时钟根据AudioFreq设置 (44.1khz vs 48khz groups) */
  BSP_AUDIO_OUT_ClockConfig(&I2Sext_InitStructure,_usAudioFreq, NULL); /* Clock config is shared between AUDIO IN and OUT */
        /* 打开 I2S2 APB1 时钟 */
        WM8978_CLK_ENABLE();
        /* 复位 SPI1 外设到缺省状态 */
        HAL_I2S_DeInit(&I2Sext_InitStructure);
        /* I2S2 外设配置 */
        I2Sext_InitStructure.Instance = WM8978_I2Sx_SPI;
        I2Sext_InitStructure.Init.Mode = I2S_MODE_MASTER_RX;                        /* 配置I2S工作模式 */
        I2Sext_InitStructure.Init.Standard = _usStandard;                                /* 接口标准 */
        I2Sext_InitStructure.Init.DataFormat = _usWordLen;                                /* 数据格式,16bit */
        I2Sext_InitStructure.Init.MCLKOutput = I2S_MCLKOUTPUT_ENABLE;        /* 主时钟模式 */
        I2Sext_InitStructure.Init.AudioFreq = _usAudioFreq;                        /* 音频采样频率 */
        I2Sext_InitStructure.Init.CPOL = I2S_CPOL_LOW;
        if(HAL_I2S_Init(&I2Sext_InitStructure) != HAL_OK)
      printf("I2S初始化失败\r\n");
发表于 2022-4-27 09:35:24 | 显示全部楼层
这个要看HAL库代码是否做处理了,
像串口,不同主频下,串口波特率有做适配,你也可以实际测试下就知道了,或者分析HAL源码。
GMT+8, 2026-10-25 20:29 , Processed in 0.278979 second(s), 24 queries .
