查看: 2003|回复: 4
求教!STM32F4 的RTC库函数问题
发表于 2022-4-24 17:12:11 | 显示全部楼层 |阅读模式
在HAL stm32f4xx_hal_rtc.c 文件中RTC时间读取和写入函数中为何 sTime->TimeFormat 是偏移16U? 查看寄存器位22才是TimeFormat 对应的位,难道不是应该偏移22u吗?求教大佬!
  /* Fill the structure fields with the read parameters */
  sTime->Hours = (uint8_t)((tmpreg & (RTC_TR_HT | RTC_TR_HU)) >> 16U);
  sTime->Minutes = (uint8_t)((tmpreg & (RTC_TR_MNT | RTC_TR_MNU)) >> 8U);
  sTime->Seconds = (uint8_t)(tmpreg & (RTC_TR_ST | RTC_TR_SU));
  sTime->TimeFormat = (uint8_t)((tmpreg & (RTC_TR_PM)) >> 16U);
发表于 2022-4-24 21:32:32 | 显示全部楼层
#define RTC_TR_PM_Pos                 (22U)
#define RTC_TR_PM_Msk                 (0x1UL << RTC_TR_PM_Pos)                  /*!< 0x00400000 */
HAL_StatusTypeDef HAL_RTC_GetTime(RTC_HandleTypeDef *hrtc, RTC_TimeTypeDef *sTime, uint32_t Format)
  uint32_t tmpreg = 0U;
  /* Check the parameters */
  assert_param(IS_RTC_FORMAT(Format));
  /* Get subseconds value from the corresponding register */
  sTime->SubSeconds = (uint32_t)(hrtc->Instance->SSR);
  /* Get SecondFraction structure field from the corresponding register field*/
  sTime->SecondFraction = (uint32_t)(hrtc->Instance->PRER & RTC_PRER_PREDIV_S);
  /* Get the TR register */
  tmpreg = (uint32_t)(hrtc->Instance->TR & RTC_TR_RESERVED_MASK);
  sTime->Hours      = (uint8_t)((tmpreg & (RTC_TR_HT  | RTC_TR_HU))  >> RTC_TR_HU_Pos);
  sTime->Minutes    = (uint8_t)((tmpreg & (RTC_TR_MNT | RTC_TR_MNU)) >> RTC_TR_MNU_Pos);
  sTime->Seconds    = (uint8_t)( tmpreg & (RTC_TR_ST  | RTC_TR_SU));
  sTime->TimeFormat = (uint8_t)((tmpreg & (RTC_TR_PM))               >> RTC_TR_PM_Pos);
  /* Check the input parameters format */
  if (Format == RTC_FORMAT_BIN)
    /* Convert the time structure parameters to Binary format */
    sTime->Hours = (uint8_t)RTC_Bcd2ToByte(sTime->Hours);
    sTime->Minutes = (uint8_t)RTC_Bcd2ToByte(sTime->Minutes);
    sTime->Seconds = (uint8_t)RTC_Bcd2ToByte(sTime->Seconds);
  return HAL_OK;
 楼主| 发表于 2022-4-25 11:04:24 | 显示全部楼层
#define RTC_TR_PM_M ...
硬汉哥你这贴的是H7的hal库函数吗?我看h7生成出来的是对的,但是F4的hal库函数里面好像就是错的
More we do, more we can do.
发表于 2022-4-25 13:41:19 | 显示全部楼层
它这写法缺点是位不在bit0,如果用 TimeFormat != 0来判断格式,也不会有问题。
发表于 2022-4-25 17:19:44 | 显示全部楼层
我这是最新版的F4 HAL库
GMT+8, 2026-11-25 11:32 , Processed in 0.828373 second(s), 27 queries .
