查看: 8659|回复: 7
[DSP] ARM DSP库新增正切函数arm_atan2_f32.c,arm_atan2_q15.c等
发表于 2022-4-23 00:52:02 | 显示全部楼层 |阅读模式
CMSIS_5/CMSIS/DSP/Source/FastMathFunctions at develop · ARM-software/CMSIS_5 (github.com)
 * Project:      CMSIS DSP Library
 * Title:        arm_atan2_f32.c
 * Description:  float32 Arc tangent of y/x
 * $Date:        06 July 2021
 * $Revision:    V1.10.0
 * Target Processor: Cortex-M and Cortex-A cores
 * Copyright (C) 2010-2021 ARM Limited or its affiliates. All rights reserved.
 * SPDX-License-Identifier: Apache-2.0
 * Licensed under the Apache License, Version 2.0 (the License); you may
 * not use this file except in compliance with the License.
 * You may obtain a copy of the License at
 * [url]www.apache.org/licenses/LICENSE-2.0[/url]
 * Unless required by applicable law or agreed to in writing, software
 * distributed under the License is distributed on an AS IS BASIS, WITHOUT
 * WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
 * See the License for the specific language governing permissions and
 * limitations under the License.
#include "dsp/fast_math_functions.h"
atan for argument between in [0, 1.0]
#define ATANHALFF32 0.463648f
#define PIHALFF32 1.5707963267948966192313f
#define ATAN2_NB_COEFS_F32 10
static const float32_t atan2_coefs_f32[ATAN2_NB_COEFS_F32]={0.0f
,1.0000001638308195518f
,-0.0000228941363602264f
,-0.3328086544578890873f
,-0.004404814619311061f
,0.2162217461808173258f
,-0.0207504842057097504f
,-0.1745263362250363339f
,0.1340557235283553386f
,-0.0323664125927477625f
__STATIC_FORCEINLINE float32_t arm_atan_limited_f32(float32_t x)
    float32_t res=atan2_coefs_f32[ATAN2_NB_COEFS_F32-1];
    int i=1;
    for(i=1;i<ATAN2_NB_COEFS_F32;i++)
        res = x*res + atan2_coefs_f32[ATAN2_NB_COEFS_F32-1-i];
    return(res);
__STATIC_FORCEINLINE float32_t arm_atan_f32(float32_t x)
   int sign=0;
   float32_t res=0.0f;
   if (x < 0.0f)
      sign=1;
      x=-x;
   if (x > 1.0f)
      x = 1.0f / x;
      res = PIHALFF32 - arm_atan_limited_f32(x);
     res += arm_atan_limited_f32(x);
   if (sign)
     res = -res;
   return(res);
  @ingroup groupFastMath
  @defgroup atan2 ArcTan2
  Computing Arc tangent only using the ratio y/x is not enough to determine the angle
  since there is an indeterminacy. Opposite quadrants are giving the same ratio.
  ArcTan2 is not using y/x to compute the angle but y and x and use the sign of y and x
  to determine the quadrant.
  @addtogroup atan2
  @brief       Arc Tangent of y/x using sign of y and x to get right quadrant
  @param[in]   y  y coordinate
  @param[in]   x  x coordinate
  @param[out]  result  Result
  @return  error status.
  @par         Compute the Arc tangent of y/x:
                   The sign of y and x are used to determine the right quadrant
                   and compute the right angle.
arm_status arm_atan2_f32(float32_t y,float32_t x,float32_t *result)
    if (x > 0.0f)
        *result=arm_atan_f32(y/x);
        return(ARM_MATH_SUCCESS);
    if (x < 0.0f)
        if (y > 0.0f)
           *result=arm_atan_f32(y/x) + PI;
        else if (y < 0.0f)
           *result=arm_atan_f32(y/x) - PI;
            if (signbit(y))
               *result= -PI;
               *result= PI;
    if (x == 0.0f)
        if (y > 0.0f)
            *result=PIHALFF32;
        if (y < 0.0f)
            *result=-PIHALFF32;
    return(ARM_MATH_NANINF);
  @} end of atan2 group
发表于 2022-4-23 09:12:45 | 显示全部楼层
这个好,SDR解调FM正好用上。
 楼主| 发表于 2022-4-23 09:31:05 | 显示全部楼层
pspice 发表于 2022-4-23 09:12
这个好,SDR解调FM正好用上。
不容易,终于开始完善三角函数支持了。
发表于 2022-8-17 17:27:44 | 显示全部楼层
棒。正好机器人逆运动学要用
发表于 2023-5-28 19:44:06 | 显示全部楼层
请问一下,最简单的移植方法是什么样的啊?
 楼主| 发表于 2023-5-29 01:33:41 | 显示全部楼层
最简单的办法是MDK RTE一键添加。
DSP视频教程第2期:系统介绍ARM DSP数字信号处理库以及超简单的移植方法分享(2022-01-27)
https://forum.anfulai.cn/forum.p ... 0766&fromuid=58
发表于 2023-6-25 11:34:35 | 显示全部楼层
最新版的ARM DSP地址是多少呢,楼主位地址失效了
 楼主| 发表于 2023-6-25 14:36:16 | 显示全部楼层
DSP库独立出来了
https://github.com/ARM-software/CMSIS-DSP
GMT+8, 2026-10-25 14:01 , Processed in 0.340000 second(s), 27 queries .
