查看: 3369|回复: 2
[RL-RTX] RTX系统下串口DMA第一帧发送数据全为0,第二帧正常
发表于 2022-3-29 15:21:07 | 显示全部楼层 |阅读模式
1、使用RTX系统后,串口DMA发送数据第一帧全为0,但是数据个数是对的,封装的发送函数如下ALIGN_32BYTES(__attribute__((section(".ARM.__at_0x24000000")))) uint8_t send_com8_buff[BUFFER_SIZE];//
ALIGN_32BYTES(__attribute__((section(".ARM.__at_0x24000100")))) uint8_t send_com1_buff[BUFFER_SIZE];//
ALIGN_32BYTES(__attribute__((section(".ARM.__at_0x24000200")))) uint8_t send_com2_buff[BUFFER_SIZE];//
ALIGN_32BYTES(__attribute__((section(".ARM.__at_0x24000300")))) uint8_t send_com4_buff[BUFFER_SIZE];//
ALIGN_32BYTES(__attribute__((section(".ARM.__at_0x24000400")))) uint8_t send_com6_buff[BUFFER_SIZE];//
ALIGN_32BYTES(__attribute__((section(".ARM.__at_0x24000500")))) uint8_t send_com3_buff[BUFFER_SIZE];//
uint16_t comSendBuf(COM_PORT_E _ucPort, uint8_t* _ucaBuf, uint16_t _usLen)
        UART_T* pUart;
        pUart = ComToUart(_ucPort);
        USART_TypeDef* Usart = pUart->uart;
        if (Usart == USART1)
                SCB_InvalidateDCache_by_Addr((uint32_t*)send_com1_buff, 256);
                memcpy(send_com1_buff, _ucaBuf, _usLen);
                if (HAL_DMA_GetState(&USART1_DMA_Handle_TX) == HAL_DMA_STATE_BUSY)//连续发送时后面加系统延时
                        return 1;
                HAL_UART_Transmit_DMA(&Usart1Handle, send_com1_buff, _usLen);
        if (Usart == USART2)
                SCB_InvalidateDCache_by_Addr((uint32_t*)send_com2_buff, 256);
                memcpy(send_com2_buff, _ucaBuf, _usLen);
                if (HAL_DMA_GetState(&USART2_DMA_Handle_TX) == HAL_DMA_STATE_BUSY)//连续发送时后面加系统延时
                {                        return 2;
                HAL_UART_Transmit_DMA(&Usart2Handle, send_com2_buff, _usLen);
                /*for (i = 0; i < _usLen; i++)
                        HAL_UART_Transmit(&Usart2Handle, _ucaBuf++, 1, 1000);
        if (Usart == USART3)
                SCB_InvalidateDCache_by_Addr((uint32_t*)send_com3_buff, 256);
                memcpy(send_com3_buff, _ucaBuf, _usLen);
                if (HAL_DMA_GetState(&USART3_DMA_Handle_TX) != HAL_DMA_STATE_READY)//连续发送时后面加系统延时
                        return 3;
                HAL_UART_Transmit_DMA(&Usart3Handle, send_com3_buff, _usLen);
        if (Usart == UART4)
                SCB_InvalidateDCache_by_Addr((uint32_t*)send_com4_buff, 256);
                memcpy(send_com4_buff, _ucaBuf, _usLen);
                if (HAL_DMA_GetState(&UART4_DMA_Handle_TX) == HAL_DMA_STATE_BUSY)//连续发送时后面加系统延时
                        return 4;
                HAL_UART_Transmit_DMA(&Uart4Handle, send_com4_buff, _usLen);
        if (Usart == USART6)
                SCB_InvalidateDCache_by_Addr((uint32_t*)send_com6_buff, 256);
                memcpy(send_com6_buff, _ucaBuf, _usLen);
                if (HAL_DMA_GetState(&USART6_DMA_Handle_TX) == HAL_DMA_STATE_BUSY)//连续发送时后面加系统延时
                        return 6;
                HAL_UART_Transmit_DMA(&Usart6Handle, send_com6_buff, _usLen);
        if (Usart == UART8)
                SCB_InvalidateDCache_by_Addr((uint32_t*)send_com8_buff, 256);
                memcpy(send_com8_buff, _ucaBuf, _usLen);
                if (HAL_DMA_GetState(&UART8_DMA_Handle_TX) == HAL_DMA_STATE_BUSY)//连续发送时后面加系统延时
                        bsp_DelayMS(1);//使用操作系统时,使用系统延时
                        return 8;
                HAL_UART_Transmit_DMA(&Uart8Handle, send_com8_buff, _usLen);
        return _usLen;
2、在线程中调佣发送函数
void task_check(void *argument)
        const uint16_t usFrequency = 200; /* 延迟周期 */
        uint32_t tick;
        static unsigned int cnt = 0;
        static int num = 0;
        /* 获取当前时间 */
        int i=0;
        //my_file_opt_t msg;
    while(1)
                osDelay(TASK_IDLE_CHECK*10);
                bsp_LedToggle(1);
                /* 相对延迟 */
                //tick += usFrequency;
                //osDelayUntil(tick);
                check_data_process();//自检信息处理
                cnt ++;
                if(cnt%25 == 0)
                        run_event_create(1,1,&test_log[0]);
                test_buf[0] = 0x12;
                test_buf[1] = 0x23;
                test_buf[2] = 0x34;
                test_buf[3] = 0x45;
                test_buf[4] = 0x56;
                test_buf[5] = 0x67;
                        comSendBuf(COM3,test_buf,6);
发表于 2022-3-29 15:57:34 | 显示全部楼层
串口DMA发送前应该做Cache 的Clean操作,简单省事些,直接关闭AXI SRAM的Cache试试。
 楼主| 发表于 2022-3-29 17:19:29 | 显示全部楼层
硬汉哥,可以了,串口DMA发送前使用了SCB_CleanDCache();,能正常发送了。
GMT+8, 2026-11-25 21:49 , Processed in 0.142744 second(s), 24 queries .
