查看: 2835|回复: 1
RL-USB V6.X的USB Host设备插拔情况回调函数
发表于 2022-3-3 10:33:22 | 显示全部楼层 |阅读模式
  1. #include <Board_LED.h>
  2. #include <rl_usb.h>
  3. void USBH_Notify (uint8_t ctrl, uint8_t port, uint8_t device, USBH_NOTIFY notify) {
  4.   switch (notify) {
  5.     case USBH_NOTIFY_CONNECT:
  6.       // A new device was connected on port
  7.       LED_On(0);
  8.       break;
  9.     case USBH_NOTIFY_DISCONNECT:
  10.       // A device was dis-connected from a port
  11.       LED_Off(0);
  12.       break;
  13.     case USBH_NOTIFY_OVERCURRENT:
  14.       // An overcurrent has happened on a port
  15.       break;
  16.     case USBH_NOTIFY_REMOTE_WAKEUP:
  17.       // Resume signaling has started on a port
  18.       break;
  19.     case USBH_NOTIFY_READY:
  20.       // Device was enumerated, initialized and is ready for communication
  21.       break;
  22.     case USBH_NOTIFY_UNKNOWN_DEVICE:
  23.       // A new device was connected but USB Host does not have a driver for it
  24.       break;
  25.     case USBH_NOTIFY_INSUFFICIENT_POWER:
  26.       // A new device was connected but we can not supply it with enough power
  27.       break;
  28.     case USBH_NOTIFY_CONFIGURATION_FAILED:
  29.       // A new device was connected but there aren't enough of resources to use it
  30.       break;
  31.     case USBH_NOTIFY_INITIALIZATION_FAILED:
  32.       // A new device was connected but initialization of it has failed
  33.       break;
  34.   }
  35. }
  36. int main (void)  {
  37.   ..
  38.   LED_Initialize();
  39.   USBH_Initialize(0);               // USB Host 0 Initialize
  40.   ..
  41.   USBH_Uninitialize(0);             // USB Host 0 De-Initialize
  42.   ..
  43. }
发表于 2024-2-1 15:59:34 | 显示全部楼层
硬汉哥你好,这有样例吗
GMT+8, 2026-10-25 23:14 , Processed in 0.136449 second(s), 27 queries .
