查看: 2730|回复: 5
ThreadX USBX升级至V6.1.10,可以独立使用了,不依赖ThreadX内核(2022-02-04)
发表于 2022-2-4 21:37:58 | 显示全部楼层 |阅读模式
论坛下载:
https://forum.anfulai.cn/forum.php?mod=viewthread&tid=97925
更新记录:
  1. Azure RTOS USBX 6.1.10 release contains the following features and changes:
  2. Added standalone mode support:
  3.     multiple files changed.
  4. Refined macros names for RTOS calls.
  5.     multiple files changed.
  6. Added host request length check for device DFU UPLOAD request, file modified:
  7.     ux_device_class_dfu_control_request.c
  8. Improved hub TT protocol handling, files modified:
  9.     ux_api.h
  10.     ux_host_class_hub_descriptor_get.c
  11. Added device audio feedback endpoint support, files modified/added:
  12.     ux_user_sample.h
  13.     ux_device_class_audio.*
  14. Fixed device audio write frame length check, files modified:
  15.     ux_device_class_audio_frame_write.c
  16.     ux_device_class_audio_write_frame_commit.c
  17. Added HID interrupt OUT transfer support, files modified/added:
  18.     ux_api.h
  19.     ux_user_sample.h
  20.     ux_device_class_hid.*
  21.     ux_host_class_hid_interrupt_endpoint_search.c
  22.     ux_host_class_hid_report_set.c
  23. Added option to enable device class code validation on host enumeration, files modified:
  24.     ux_user_sample.h
  25.     ux_host_stack_device_descriptor_read.c
  26. Refined device configuration power check on host side, files modified:
  27.     ux_host_stack_configuration_set.c
  28.     ux_host_stack_device_configuration_reset.c
  29.     ux_host_stack_device_configuration_select.c
  30.     ux_host_stack_new_device_create.c
  31. Fixed periodic transfer issue for OHCI driver, files modified:
  32.     ux_hcd_ohci.h
  33.     ux_hcd_ohci_initialize.c
  34. Fixed completion code on aborting, files modified:
  35.     ux_device_stack_transfer_abort.c
  36.     ux_device_class_cdc_acm_ioctl.c
  37.     ux_device_class_pima_control_request.c
  38. Updated device PIMA implementation.
  39.     ux_device_class_pima.*
  40. Fixed a device audio stream instance uninitialize issue, file modified:
  41.     ux_device_class_audio_unitialize.c
  42. Added device printer support, files modified/added:
  43.     ux_api.h
  44.     ux_system.h
  45.     ux_device_stack_control_request_process.c
  46.     ux_device_stack_initialize.c
  47.     ux_device_class_printer.*
  48. Allowed answering part of data to fit host length when range parameters are requsted, file modified:
  49.     ux_device_class_audio20_control_process.c
发表于 2022-2-16 00:38:27 | 显示全部楼层
已经在玩了,接口变化有点大,上层应用和controller适配层都需要调整。。
发表于 2022-3-14 15:44:34 | 显示全部楼层
记得硬汉做过移植的,移植教程有没?
 楼主| 发表于 2022-3-14 15:55:58 | 显示全部楼层
yuntian 发表于 2022-3-14 15:44
记得硬汉做过移植的,移植教程有没?
独立的教程没做,只做了带系统的。
ThreadX USBX协议栈教程更新记录贴,前5章发布(2021-10-11)
https://forum.anfulai.cn/forum.p ... 8546&fromuid=58
发表于 2022-4-11 14:25:32 | 显示全部楼层
我看了下代码,USB里面感觉还是有许多接口是用了threadx了,我想把usbx移植到rt-thread下面,rt-thread那个USB 那个功能太少了
发表于 2022-4-11 14:28:18 | 显示全部楼层
是和内核分离了吗,我现在想移植到rt-thread上去
GMT+8, 2026-10-26 00:38 , Processed in 0.168249 second(s), 24 queries .
