查看: 1862|回复: 3
[有问必答] RTT Viewer
发表于 2022-1-19 11:21:41 | 显示全部楼层 |阅读模式
各位有没有替代RTT Viewer的上位机,可以实时自动将数据保存到文件的?
More we do, more we can do.
发表于 2022-1-19 14:27:30 | 显示全部楼层
看了下手册,支持第三方软件集成:
RTT can also be integrated in any other PC application like a debugger or a data visualizer in either of two ways.
The application can establish a socket connection to the RTT Telnet Server which is opened on localhost:19021 when a J-Link connection is active.
The application creates its own connection to J-Link and uses the J-Link RTT API which is part of the J-Link SDK to directly configure and use RTT.
发表于 2022-1-19 14:28:55 | 显示全部楼层
此外,它本身提供了记录到文件的功能:
  1. With J-Link RTT Logger, data from Up-Channel 1 can be read and logged to a file.
 楼主| 发表于 2022-1-19 14:35:09 | 显示全部楼层
emwin 发表于 2022-1-19 14:27
看了下手册,支持第三方软件集成:
感谢
GMT+8, 2026-11-22 17:25 , Processed in 0.486396 second(s), 23 queries .
