查看: 2998|回复: 6
[μCOS-III] 开源一个通用通讯协议解析代码
发表于 2021-12-29 10:57:27 | 显示全部楼层 |阅读模式
通用的一般格式:帧头+data+校验+帧尾
demo如下:
#include "Console.h"
#include "cQueue.h"
#include "CalculationTimeDelay.h"
#include "CommonProtocol.h"
#if USE_CONSOLE
tyu8Queue sTxQueue;
tyu8Queue sRxQueue;
#ifdef    USE_UCOS_III
static    OS_MUTEX  Logmutex;
#define   TaskCONSOLETCBSTAK_SIZE   128u
#define   TASK_CONSOLE_PRIO      10
static  OS_MUTEX  printflogmutex;
static  OS_TCB    TASKCONSOLETCB;
static  CPU_STK   TaskCONSOLEWRLOCALTCBSTAK[TaskCONSOLETCBSTAK_SIZE];
static  void ConsoleTaskUser(void *p_arg);
static  void CreatTask(void);
static  ProtocolData  _p;
static  unsigned char consolegetbuf[128];
static  void consoleOnGetFrame(U8* buf, U32 bufLen, void* lParam);
#endif
#endif
void Init_ConsoleSerial(void)
#if USE_CONSOLE
  InitQueue(sTxQueue);
  InitQueue(sRxQueue);
  SERIALPORTINIT;
#ifdef  USE_UCOS_III
  U16 stx = CONSOLE_STX;
  U16 etx = CONSOLE_ETX;
  Init_CP(&_p,consolegetbuf,128,CheckSum_CP,consoleOnGetFrame,NULL);
  SetSTX_CP(&_p, (CPU_INT08U *)&stx, sizeof(stx));
  SetETX_CP(&_p, (CPU_INT08U *)&etx, sizeof(etx));
  SetCK_CP(&_p, 2, 4);
  OS_ERR err;
  OSMutexCreate ((OS_MUTEX *)&Logmutex, (CPU_CHAR *)"MutexForlog", (OS_ERR *)&err);
  OSTaskCreate((OS_TCB       *)&TASKCONSOLETCB,
               (CPU_CHAR     *)"Taskconsole",
               (OS_TASK_PTR   )ConsoleTaskUser,
               (void         *)0,
               (OS_PRIO       )TASK_CONSOLE_PRIO,
               (CPU_STK      *)&TaskCONSOLEWRLOCALTCBSTAK[0],
               (CPU_STK_SIZE  )TaskCONSOLETCBSTAK_SIZE / 10,
               (CPU_STK_SIZE  )TaskCONSOLETCBSTAK_SIZE,
               (OS_MSG_QTY    )5,
               (OS_TICK       )0,
               (void         *)0,
               (OS_OPT        )(OS_OPT_TASK_STK_CHK | OS_OPT_TASK_STK_CLR),
               (OS_ERR       *)&err);
#endif
#endif
  while(1)
    {#ifdef USE_UCOS_III
      OS_ERR err;
      OSTimeDly(2, OS_OPT_TIME_DLY, &err);
#endif
      uint8_t getdata;
      while(1)
          if(!QueueEmpty(sRxQueue))
              PopQueue(sRxQueue,getdata);
              PutDataSingleByte_CP(&_p,getdata);
              AnalyzeData_CP(&_p);
//这里就是解析成功后的回调函数
  u8 bufer[128];
  for(int a=0; a<bufLen; a++)
      bufer[a]=buf[a];
参与人数 1金币 +100 收起 理由
eric2013 + 100 很给力!
 楼主| 发表于 2021-12-29 11:04:58 | 显示全部楼层
此解析算法可以处理粘包,分包,滤除无用数据。易用,稳定,可靠。
发表于 2021-12-29 11:18:47 | 显示全部楼层
感谢楼主分享。
发表于 2021-12-30 10:30:15 | 显示全部楼层
插个眼
发表于 2021-12-30 14:34:30 | 显示全部楼层
很好用的架构。学习一下。
发表于 2021-12-30 15:05:27 | 显示全部楼层
学习一下
发表于 2023-1-31 00:26:19 | 显示全部楼层
插个眼
GMT+8, 2026-11-23 23:58 , Processed in 0.931463 second(s), 25 queries .
