查看: 3072|回复: 7
[ThreadX全家桶] ThreadX在STM32H7上面使用是不是免费的?
发表于 2021-11-18 16:54:36 | 显示全部楼层 |阅读模式
ThreadX在STM32H7上面使用是不是免费的?不敢相信呀,请大神帮忙确认一下
LICENSED HARDWARE LIST
Last Updated: 2021-04-01
Microsoft has entered into OEM Agreements with manufacturers of the following
microprocessors and microcontrollers (the “hardware”) to enable those
manufacturers to include and distribute Azure RTOS in certain hardware. If you
have obtained and/or are developing on microprocessor(s) and/or
microcontroller(s) (“hardware”) listed below you inherit the “Distribution and
Production Use” rights in Section 2 of the Microsoft Software License Terms for
Microsoft Azure RTOS. If hardware is not listed below, you do not have those
rights.
STMicroelectronics:
    STM32 MCUs
    STM32 MPUs
MediaTek:
    MT3620 MCU (Azure Sphere)
Microchip:
    PIC 32-bit MCUs
    SAM 32-bit MCUs
    SAM 32-bit MPUs
NXP:
    i.MX RT10xx and RT116x/7x series crossover MCUs
    LPC5500 series
Renesas:
    Synergy Platform
    RX Family of MCUs
    RA Family of MCUs
    RZ Family of MPUs
More coming soon. Please check back frequently for updates.
发表于 2021-11-18 16:57:10 | 显示全部楼层
毋庸置疑,ST全系列MCUs/MPUs都可以用。
 楼主| 发表于 2021-11-18 16:58:32 | 显示全部楼层
ThreadX + FileX + UsbX + NexDuo + GuiX,这些在STM32H7上使用,都是免费的吗?
 楼主| 发表于 2021-11-18 17:00:14 | 显示全部楼层
哈哈哈,搞起,以前收费,一直不敢用在产品上。
发表于 2021-11-18 17:22:28 | 显示全部楼层
按MS官网的组织,Azure RTOS是一个集合,Threadx全称应该是Azure RTOS Threadx,Filex应该是Azure RTOS Filex,等等。这样看来,你列的那些,都是可用的。
发表于 2021-11-18 17:25:19 | 显示全部楼层
不知道GUIx是否包含在内?
发表于 2021-11-18 17:36:20 | 显示全部楼层
morning_enr6U 发表于 2021-11-18 17:25
不知道GUIx是否包含在内?
所有组件免费。
发表于 2021-11-18 21:02:20 来自手机 | 显示全部楼层
放心大胆得用,别是国产芯片就行,国产芯片使用要自己掏钱付费了,哈哈
GMT+8, 2026-11-23 21:43 , Processed in 1.657293 second(s), 24 queries .
