查看: 2238|回复: 3
[ThreadX全家桶] 请教一个问题 产品资格的问题
发表于 2021-10-25 15:42:12 | 显示全部楼层 |阅读模式
问题1 如果我使用 ST的MCU做了一个PLC 或者 变频器 或者 手持设备。用了ThreadX,需要交钱吗?
问题2 如果我使用的是其他的国产MCU 做上述产品,需要交钱吗?
请知道的同学和前辈指导。
 楼主| 发表于 2021-10-25 15:43:40 | 显示全部楼层
我现在需要学习并后续使用一种RTOS,FreeRTOS或者ThreadX。纠结中。
发表于 2021-10-25 16:14:46 | 显示全部楼层
使用如下厂家芯片,免费商用。国产的还不行,国产估计后面也有厂家加入
threadx/LICENSED-HARDWARE.txt at master · azure-rtos/threadx (github.com)
  1. LICENSED HARDWARE LIST
  2. Last Updated: 2021-04-01
  3. Microsoft has entered into OEM Agreements with manufacturers of the following
  4. microprocessors and microcontrollers (the “hardware”) to enable those
  5. manufacturers to include and distribute Azure RTOS in certain hardware. If you
  6. have obtained and/or are developing on microprocessor(s) and/or
  7. microcontroller(s) (“hardware”) listed below you inherit the “Distribution and
  8. Production Use” rights in Section 2 of the Microsoft Software License Terms for
  9. Microsoft Azure RTOS. If hardware is not listed below, you do not have those
  10. rights.
  11. STMicroelectronics:
  12.     STM32 MCUs
  13.     STM32 MPUs
  14. MediaTek:
  15.     MT3620 MCU (Azure Sphere)
  16. Microchip:
  17.     PIC 32-bit MCUs
  18.     SAM 32-bit MCUs
  19.     SAM 32-bit MPUs
  20. NXP:
  21.     i.MX RT10xx and RT116x/7x series crossover MCUs
  22.     LPC5500 series
  23. Renesas:
  24.     Synergy Platform
  25.     RX Family of MCUs
  26.     RA Family of MCUs
  27.     RZ Family of MPUs
  28. --------------------------------------------------------------------------------
  29. More coming soon. Please check back frequently for updates.
 楼主| 发表于 2021-10-25 16:43:03 | 显示全部楼层
谢谢老大回答。郁闷了。。。
GMT+8, 2026-11-23 21:42 , Processed in 1.104675 second(s), 24 queries .
