查看: 6491|回复: 6
STM32F4的新版HAL库增加的几个原子操作API
发表于 2021-10-7 09:14:31 | 显示全部楼层 |阅读模式
代码:
  1. /* Use of CMSIS compiler intrinsics for register exclusive access */
  2. /* Atomic 32-bit register access macro to set one or several bits */
  3. #define ATOMIC_SET_BIT(REG, BIT)                             \
  4.   do {                                                       \
  5.     uint32_t val;                                            \
  6.     do {                                                     \
  7.       val = __LDREXW((__IO uint32_t *)&(REG)) | (BIT);       \
  8.     } while ((__STREXW(val,(__IO uint32_t *)&(REG))) != 0U); \
  9.   } while(0)
  10. /* Atomic 32-bit register access macro to clear one or several bits */
  11. #define ATOMIC_CLEAR_BIT(REG, BIT)                           \
  12.   do {                                                       \
  13.     uint32_t val;                                            \
  14.     do {                                                     \
  15.       val = __LDREXW((__IO uint32_t *)&(REG)) & ~(BIT);      \
  16.     } while ((__STREXW(val,(__IO uint32_t *)&(REG))) != 0U); \
  17.   } while(0)
  18. /* Atomic 32-bit register access macro to clear and set one or several bits */
  19. #define ATOMIC_MODIFY_REG(REG, CLEARMSK, SETMASK)                          \
  20.   do {        \
  21.     uint32_t val;                                                          \
  22.     do {        \
  23.       val = (__LDREXW((__IO uint32_t *)&(REG)) & ~(CLEARMSK)) | (SETMASK); \
  24.     } while ((__STREXW(val,(__IO uint32_t *)&(REG))) != 0U);               \
  25.   } while(0)
  26. /* Atomic 16-bit register access macro to set one or several bits */
  27. #define ATOMIC_SETH_BIT(REG, BIT)                            \
  28.   do {                                                       \
  29.     uint16_t val;                                            \
  30.     do {                                                     \
  31.       val = __LDREXH((__IO uint16_t *)&(REG)) | (BIT);       \
  32.     } while ((__STREXH(val,(__IO uint16_t *)&(REG))) != 0U); \
  33.   } while(0)
  34. /* Atomic 16-bit register access macro to clear one or several bits */
  35. #define ATOMIC_CLEARH_BIT(REG, BIT)                          \
  36.   do {                                                       \
  37.     uint16_t val;                                            \
  38.     do {                                                     \
  39.       val = __LDREXH((__IO uint16_t *)&(REG)) & ~(BIT);      \
  40.     } while ((__STREXH(val,(__IO uint16_t *)&(REG))) != 0U); \
  41.   } while(0)
  42. /* Atomic 16-bit register access macro to clear and set one or several bits */
  43. #define ATOMIC_MODIFYH_REG(REG, CLEARMSK, SETMASK)                         \
  44.   do {        \
  45.     uint16_t val;                                                          \
  46.     do {        \
  47.       val = (__LDREXH((__IO uint16_t *)&(REG)) & ~(CLEARMSK)) | (SETMASK); \
  48.     } while ((__STREXH(val,(__IO uint16_t *)&(REG))) != 0U);               \
  49.   } while(0)
参与人数 1金币 +10 收起 理由
WZH + 10 很给力!
 楼主| 发表于 2021-10-7 09:18:37 | 显示全部楼层
RTX5里面也有一大批原子操作函数。
发表于 2021-11-12 14:47:58 | 显示全部楼层
 楼主| 发表于 2021-11-13 08:53:48 | 显示全部楼层
云琴箫龙 发表于 2021-11-12 14:47
请教硬汉哥为何直接调用会有个黄色警告?
回头我试试,ST的这个还没有测试过。
发表于 2022-5-11 09:48:20 | 显示全部楼层
请问在哪里可以查询到这种原子操作呢,在F4的HAL库的哪个文件里?
发表于 2023-6-20 10:16:52 | 显示全部楼层
请教硬汉哥为何直接调用会有个黄色警告?
请问您这个问题解决了没,加了头文件也还有警告,但编译不报错。
 楼主| 发表于 2023-6-20 11:08:22 | 显示全部楼层
编译不报错没关系
GMT+8, 2026-11-25 10:08 , Processed in 0.173600 second(s), 28 queries .
