查看: 8136|回复: 1
stm8l 外部脉冲计数始终为零。。。求助
发表于 2015-7-10 15:42:41 | 显示全部楼层 |阅读模式
RT:我想用stm8L的 外部时钟源模式2 进行计频,我调用了tim2的库函数,TIM2_CH1通道(PB0)计数,结果一直为零。
程序:
void TIM2_CH1_ETR_Init(void)
        TIM2_DeInit();    //复位TIME2
        CLK_PeripheralClockConfig(CLK_Peripheral_TIM2,ENABLE); //开启TIME2的时钟中断
        FLASH_Unlock(FLASH_MemType_Data);
        FLASH_ProgramOptionByte(0x5253,0x20);
        FLASH_Lock(FLASH_MemType_Data);
        GPIO_Init(GPIOB,GPIO_Pin_0,GPIO_Mode_In_PU_No_IT);
        TIM2_TimeBaseInit(TIM2_Prescaler_1,TIM2_CounterMode_Up,65535);//不分频 ,计数 65535
        TIM2_ETRClockMode2Config(TIM2_ExtTRGPSC_OFF,TIM2_ExtTRGPolarity_NonInverted,0);//没有外部触发预分频器,高电平或上升沿有效,使能外部时钟模式2
        TIM2_SelectInputTrigger(TIM2_TRGSelection_ETRF); //选择外部触发
        TIM2_ARRPreloadConfig(ENABLE);
        TIM2_ClearFlag(TIM2_FLAG_Update);
        TIM2_ITConfig(TIM2_IT_Update,ENABLE);   //打开中断
        TIM2_SetCounter(0);
        TIM2_Cmd(ENABLE);
@far @interrupt void TIM2_IRQHandler(void){
        if (TIM2_GetITStatus(TIM2_IT_Update) != RESET)             {
                TIM2_ClearITPendingBit(TIM2_IT_Update);                Cnt_a++;
然后在定时器1里面计算:
@far @interrupt void TIMER1_IRQHandler(void){
        if(TIM1_GetITStatus(TIM1_IT_Update)== SET) //溢出中断        {
                TIM1_ClearITPendingBit(TIM1_IT_Update);                TIM1_Cmd(DISABLE);
                TIM2_Cmd(DISABLE);                Frequency=Cnt_a*65535 + TIM2_GetCounter();
                TIM2_SetCounter(0);                Cnt_a = 0;
                TIM1_Cmd(ENABLE);                TIM2_Cmd(ENABLE);
              printf("the period is : %d\n",Frequency);        }
发表于 2015-7-10 16:42:56 | 显示全部楼层
一直没有用STM8,帮顶
GMT+8, 2026-11-22 14:30 , Processed in 0.288298 second(s), 24 queries .
