查看: 3999|回复: 2
[其它] Eclipse编译输出怎么清爽一点,别显示头文件路径、编译器选项之类的?
More we do, more we can do.
发表于 2021-8-5 12:30:39 | 显示全部楼层 |阅读模式
Building file: ./mid_lib_new/ui/UIAppInterface.c
Invoking: GNU ARM Cross C Compiler
arm-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O2 -ffunction-sections -fdata-sections -fno-builtin -fPIC -n -pie -fpie -fPIC -fpic -msingle-pic-base -mno-pic-data-is-text-relative -Werror -Wall -g -gdwarf-2 -DDEBUG -Dxxxxxx -I".\xxxxxx\source\demand" -I".\wuss\include" -I".\wuss\include\dev" -I".\xxxxxx\source\tariff" -I".\libsdk\libc\newlib" -I".\libsdk\libc\newlib\sys" -I".\libsdk\include" -I".\libsdk\include\sys" -I".\libsdk\include\drivers" -I".\libsdk\include\ipc" -I".\xxxxxx\source\UserInterface\EventReport" -I".\xxxxxx\source\xxxxxx\Code" -I".\xxxxxx\source\UserInterface\PP\PP_xxx\Process" -I".\xxxxxx\source\UserInterface\PP\PP_xxx" -I".\xxxxxx\source\UserInterface\display" -I".\xxxxxx\source\UserInterface\PP\PP_xxx\Class" -I".\xxxxxx\source\xxxxxx\Code\message" -I".\xxxxxx\source\LegallyRelevant" -I".\xxxxxx\source\message" -I".\xxxxxx\source\monitor" -I".\xxxxxx\source\MtrParamDefault" -I".\xxxxxx\source\message" -I".\xxxxxx\source\OC" -I".\xxxxxx\source\prepay" -I".\xxxxxx\source\record" -I".\xxxxxx\source\tariff" -I".\xxxxxx\source\UserInterface" -I".\mid_lib_new\include" -I".\xxxxxx\source\FS" -I".\mid_lib_new\ui" -I".\mid_lib_new" -I".\xxxxxx\source\AutomaticProduction" -I".\xxxxxx\source" -I".\xxxxxx\source\gcc_include" -include".\xxxxxx\source\gcc_include\zxconfig_preinc.h" -std=gnu11 -MMD -MP -MF"mid_lib_new/ui/UIAppInterface.d" -MT"mid_lib_new/ui/UIAppInterface.o" -c -o "mid_lib_new/ui/UIAppInterface.o" "./mid_lib_new/ui/UIAppInterface.c"
如上反例,编译1个就占满了输出窗口,我希望只留下第1行就行。(注:中间隐去了路径信息)
 楼主| 发表于 2021-8-5 23:30:57 | 显示全部楼层
看了下makefile的文档,解决了,命令前缀加@不打印命令本身。
发表于 2021-8-8 16:17:42 | 显示全部楼层
多谢分  享
GMT+8, 2026-11-24 15:57 , Processed in 0.248770 second(s), 26 queries .
