查看: 4353|回复: 0
[ThreadX全家桶] 备份下ThreadX GUIX的圆盘多指针设计方案
发表于 2021-8-5 09:26:08 | 显示全部楼层 |阅读模式
此贴10楼:
https://forum.anfulai.cn/forum.php?mod=viewthread&tid=106310
circular gauge 目前只支持一个指针,可以通过重写circular gauge draw实现多指针。
示例:
INT second_needle_angle = 60;
VOID custom_circular_gauge_draw(GX_CIRCULAR_GAUGE *gauge)
    GX_CIRCULAR_GAUGE_INFO *info;
    INT xcor;
    INT ycor;
    INT needle_xpos;
    INT needle_ypos;
    GX_PIXELMAP *needle;
    GX_PIXELMAP needle_rotated;
    /* Call default circular draw. */
    gx_circular_gauge_draw(gauge);
    /* Pick up pointer to the gauge information structure.  */
    info = &gauge->gx_circular_gauge_info;
    /* Retrieve the map for the second needle. */
    gx_context_pixelmap_get(GX_PIXELMAP_ID_NEEDLE, &needle);
    if (needle)
        xcor = (INT)(info->gx_circular_gauge_info_needle_xcor);
        ycor = (INT)(info->gx_circular_gauge_info_needle_ycor);
        needle_xpos = info->gx_circular_gauge_info_needle_xpos;
        needle_ypos = info->gx_circular_gauge_info_needle_ypos;
        /* Rotate the second needle pixelmap. */
        if (gx_utility_pixelmap_rotate(needle, second_needle_angle, &needle_rotated, &xcor, &ycor) == GX_SUCCESS)
            /* Calculate start position of needle pixelmap.  */
            needle_xpos = gauge->gx_widget_size.gx_rectangle_left + info->gx_circular_gauge_info_needle_xpos;
            needle_xpos -= xcor;
            needle_ypos = gauge->gx_widget_size.gx_rectangle_top + info->gx_circular_gauge_info_needle_ypos;
            needle_ypos -= ycor;
            /* Draw needle .  */
            _gx_canvas_pixelmap_draw((GX_VALUE)needle_xpos, (GX_VALUE)needle_ypos, &needle_rotated);
            /* Free rotate needle pixelmap memory.  */
            if (memory_free)
                if (needle_rotated.gx_pixelmap_aux_data)
                    memory_free((VOID*)needle_rotated.gx_pixelmap_aux_data);
                memory_free((VOID*)needle_rotated.gx_pixelmap_data);
这段代码可以放在tutorials/demo_guix_circular_gauge里使用,需要把表盘的draw函数设为custom_circular_gauge_draw。
GMT+8, 2026-11-23 21:18 , Processed in 0.679586 second(s), 24 queries .
