查看: 5258|回复: 5
[TIMER] PWM中心对齐模式
发表于 2021-7-7 09:53:14 | 显示全部楼层 |阅读模式
定时器配置输出PWM波形,中心对齐模式怎么计算占空比和周期?时钟56M
  TIM_InitStruct.Prescaler = 5599;
  TIM_InitStruct.CounterMode = LL_TIM_COUNTERMODE_CENTER_DOWN;//LL_TIM_COUNTERMODE_UP;//
  TIM_InitStruct.Autoreload = 99;
  TIM_InitStruct.ClockDivision = LL_TIM_CLOCKDIVISION_DIV1;
  LL_TIM_Init(TIM3, &TIM_InitStruct);
  LL_TIM_EnableARRPreload(TIM3);
  LL_TIM_OC_EnablePreload(TIM3, LL_TIM_CHANNEL_CH1);
  TIM_OC_InitStruct.OCMode = LL_TIM_OCMODE_PWM1;
  TIM_OC_InitStruct.OCState = LL_TIM_OCSTATE_DISABLE;
  TIM_OC_InitStruct.OCNState = LL_TIM_OCSTATE_DISABLE;
  TIM_OC_InitStruct.CompareValue = ((99+ 1 ) / 3);
  TIM_OC_InitStruct.OCPolarity = LL_TIM_OCPOLARITY_HIGH;
  LL_TIM_OC_Init(TIM3, LL_TIM_CHANNEL_CH1, &TIM_OC_InitStruct);
发表于 2021-7-7 10:27:03 | 显示全部楼层
周期计算和其它模式一样。
占空比是下面这种:
 楼主| 发表于 2021-7-7 17:37:11 | 显示全部楼层
eric2013 发表于 2021-7-7 10:27
周期计算和其它模式一样。
占空比是下面这种:
能具体给个公式吗?
发表于 2021-7-7 18:04:01 | 显示全部楼层
lindahnu 发表于 2021-7-7 17:37
能具体给个公式吗?
PWM 频率 = TIMxCLK /( Prescaler + 1) /(Period+ 1)/ 2
PMW 占空比 = Pulse/(Period + 1)
 楼主| 发表于 2021-7-8 10:26:07 | 显示全部楼层
非对称模式怎么计算高低电平时间呢?
htim3.Instance = TIM3;
  htim3.Init.Prescaler = 0;
  htim3.Init.CounterMode = TIM_COUNTERMODE_CENTERALIGNED1;
  htim3.Init.Period = 2800-1;
  htim3.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  htim3.Init.RepetitionCounter = 0;
  htim3.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
  if (HAL_TIM_PWM_Init(&htim3) != HAL_OK)
    Error_Handler();
        sConfigOC.OCMode = TIM_OCMODE_PWM2;
  sConfigOC.Pulse = 700;
  sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH;
  sConfigOC.OCNPolarity = TIM_OCNPOLARITY_HIGH;
  sConfigOC.OCFastMode = TIM_OCFAST_DISABLE;
  sConfigOC.OCIdleState = TIM_OCIDLESTATE_RESET;
  sConfigOC.OCNIdleState = TIM_OCNIDLESTATE_RESET;
  if (HAL_TIM_PWM_ConfigChannel(&htim3, &sConfigOC, TIM_CHANNEL_1) != HAL_OK)
    Error_Handler();
        sConfigOC.OCMode = TIM_OCMODE_ASSYMETRIC_PWM2;
  sConfigOC.Pulse = 1400;
  if(HAL_TIM_PWM_ConfigChannel(&htim3, &sConfigOC, TIM_CHANNEL_2) != HAL_OK)
    /* Configuration Error */
    Error_Handler();
图片显示抓到的波形,第一个是通道1,第二个是通道2,通道2的高低电平时间是怎么计算的?
发表于 2021-7-8 11:11:05 | 显示全部楼层
lindahnu 发表于 2021-7-8 10:26
非对称模式怎么计算高低电平时间呢?
STM32H7的非对称PWM模式(Asymmetric PWM mode),波形的相位差可编程
https://forum.anfulai.cn/forum.p ... 9110&fromuid=58
GMT+8, 2026-10-26 01:23 , Processed in 0.201733 second(s), 27 queries .
