查看: 3819|回复: 1
[有问必答] void BspSetTIMOutPWM函数里的TIM_Pulse有什么用?
发表于 2021-7-2 14:17:55 | 显示全部楼层 |阅读模式
void BspSetTIMOutPWM(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin_x,
                     TIM_TypeDef* TIMx,   uint8_t _ucChannel,
                     uint32_t _ulFreq,    uint32_t _ulDutyCycle)
    TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
    TIM_OCInitTypeDef TIM_OCInitStructure;
    uint16_t usPeriod;
    uint16_t usPrescaler;
    uint32_t uiTIMxCLK;
    if(0 == _ulDutyCycle)/*如果占空比为0*/
        TIM_Cmd(TIMx, DISABLE);
        BspConfigGpioOut(GPIOx, GPIO_Pin_x);
        GPIO_WriteBit(GPIOx, GPIO_Pin_x, Bit_RESET);/* PWM = 0 */
        return;
    else if(10000 == _ulDutyCycle)/*如果占空比为1*/
        GPIO_WriteBit(GPIOx, GPIO_Pin_x, Bit_SET);/* PWM = 1 */
        return;
    BspConfigTIMGpio(GPIOx, GPIO_Pin_x, TIMx, _ucChannel);
        system_stm32f4xx.c 文件中 void SetSysClock(void) 函数对时钟的配置如下:
        HCLK = SYSCLK / 1     (AHB1Periph)
        PCLK2 = HCLK / 2      (APB2Periph)
        PCLK1 = HCLK / 4      (APB1Periph)
        因为APB1 prescaler != 1, 所以 APB1上的TIMxCLK = PCLK1 x 2 = SystemCoreClock / 2;
        因为APB2 prescaler != 1, 所以 APB2上的TIMxCLK = PCLK2 x 2 = SystemCoreClock;
        APB1 定时器有 TIM2, TIM3 ,TIM4, TIM5, TIM6, TIM6, TIM12, TIM13,TIM14
        APB2 定时器有 TIM1, TIM8 ,TIM9, TIM10, TIM11
    if((TIMx == TIM1)||(TIMx == TIM8)||(TIMx == TIM9)||(TIMx == TIM10)||(TIMx == TIM11))
        /* APB2 定时器 */
        uiTIMxCLK = SystemCoreClock;
        /* APB1 定时器 */
        uiTIMxCLK = SystemCoreClock / 2;
    if(_ulFreq < 100)
        usPrescaler = 10000 - 1;
        usPeriod = (uiTIMxCLK / 10000) / _ulFreq - 1; //TIM3 假如是50Hz: usPeriod = (90 000 000 / 10000) /50  - 1 = 179
    else if(_ulFreq < 3000)
        usPrescaler = 100 - 1;
        usPeriod = (uiTIMxCLK / 100) / _ulFreq - 1;
        usPrescaler = 0;
        usPeriod = uiTIMxCLK / _ulFreq - 1;
    TIM_TimeBaseStructure.TIM_Period = usPeriod;                //上面计算是180
    TIM_TimeBaseStructure.TIM_Prescaler = usPrescaler;          // 9999
    TIM_TimeBaseStructure.TIM_ClockDivision = 0;
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_TimeBaseStructure.TIM_RepetitionCounter = 0x0000;   /* TIM1 和 TIM8 必须设置 */
    TIM_TimeBaseInit(TIMx, &TIM_TimeBaseStructure);
    TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
    TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
    TIM_OCInitStructure.TIM_Pulse = (_ulDutyCycle * usPeriod) / 10000;  // 5000 * 179 / 10000 = 13.5
    TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
    TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Disable;    /* only for TIM1 and TIM8. */
    TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;         /* only for TIM1 and TIM8. */
    TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Reset;        /* only for TIM1 and TIM8. */
    TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Reset;      /* only for TIM1 and TIM8. */
    if(1 == _ucChannel)
        TIM_OC1Init(TIMx, &TIM_OCInitStructure);
        TIM_OC1PreloadConfig(TIMx, TIM_OCPreload_Enable);
    else if(2 == _ucChannel)
        TIM_OC2Init(TIMx, &TIM_OCInitStructure);
        TIM_OC2PreloadConfig(TIMx, TIM_OCPreload_Enable);
    else if(3 == _ucChannel)
        TIM_OC3Init(TIMx, &TIM_OCInitStructure);
        TIM_OC3PreloadConfig(TIMx, TIM_OCPreload_Enable);
    else if(4 == _ucChannel)
        TIM_OC4Init(TIMx, &TIM_OCInitStructure);
        TIM_OC4PreloadConfig(TIMx, TIM_OCPreload_Enable);
    TIM_ARRPreloadConfig(TIMx, ENABLE);
    TIM_Cmd(TIMx, ENABLE);
    if((TIMx == TIM1)||(TIMx == TIM8))
        TIM_CtrlPWMOutputs(TIMx, ENABLE);
 楼主| 发表于 2021-7-2 14:19:36 | 显示全部楼层
上面应该是84 000 000,算错了
GMT+8, 2026-11-28 17:10 , Processed in 0.894008 second(s), 23 queries .
