查看: 4482|回复: 1
[有问必答] 为什么蜂鸣器关不了的?
发表于 2021-6-8 16:58:04 | 显示全部楼层 |阅读模式
代码如下:#define BEEP_ON                GPIO_SetBits(GPIOG,GPIO_Pin_8)
#define BEEP_OFF        GPIO_ResetBits(GPIOG,GPIO_Pin_8)
void  work_inflation(void)
     //任务初始化
                 unsigned short int a = Ad;                                                //此时的压力值
                 unsigned short int b = setparm_t.Fill_PressureMax;                        //充气压力上限设定值
                 unsigned short int c = setparm_t.Fill_PressureMin;                        //充气压力下限设定值
                 unsigned short int d = setparm_t.FILLTime;                                                        //充气时间
                 unsigned short int e = FillPressure;        //保存的压力值
        LOOP:
                        BEEP_OFF;
                        time_count=0;
                        work_state =WORK_IDLE;//默认进入空闲等待状态
           while(1)
                         GPIO_SetBits(GPIOF,GPIO_Pin_9);           //LED0对应引脚GPIOF.0拉高,灭  等同LED0=1;
                         GPIO_ResetBits(GPIOF,GPIO_Pin_10); //LED1对应引脚GPIOF.10拉低,亮 等同LED1=0;
                         printf("现在是充气状态");
                         //1--任务循环处理内容
                         //2-外部触发条件跳出任务
                         if(time_count==d*100)
                                 time_count = 0;
                                 e = a;
                         printf("%d",FillFlag);
                         if(FillFlag == 0)
                                 goto LOOP;
                 if(FillFlag)
                         if((a<b)&&(a>c))
                                                work_state = WORK_blance;
                                                BalanceFlag = 1;
                                                BEEP_ON;
                                                FillFlag = 0;
                                                time_count=0;
                                                work_state = WORK_exhaust;
                         work_state =WORK_exhaust;//默认进入空闲等待状态
                         time_count = 0;
条件不满足时BEEP_ON蜂鸣器响,然后按下按键改变标志位进入 goto LOOP;然后发现蜂鸣器关不掉,这是什么原因???
发表于 2021-6-9 09:20:00 | 显示全部楼层
不好意思楼主,没太看懂你代码的逻辑关系。
GMT+8, 2026-11-28 17:10 , Processed in 0.840353 second(s), 24 queries .
